Motor rotating at normal speed and then prevented from rotating
The discussion centers on the behavior of a motor under two conditions: normal rotation and being prevented from rotating. When the motor is rotating, it functions as both a resistor and an electromotive force (emf) source in series. Conversely, when the motor is stopped, it behaves solely as a resistor. The provided formula for current in the circuit illustrates these principles, highlighting the difference in operation modes. Understanding these concepts is crucial for analyzing motor circuits effectively.
Guillem_dlc
A generator of electromotive force ##100\, \textrm{V}## and internal resistance ##1\, \Omega## is connected in series to a motor. A voltmeter is connected between the terminals of the generator. When the motor is rotating at normal speed the voltmeter reads ##95\, \textrm{V}## and when the motor is prevented from rotating it reads ##85\, \textrm{V}##. Calculate:
a) the resistance of the motor (R: ##5,67\, \Omega##).
b) the counter-electromotive force of the motor (R: ##66,7\, \textrm{V}##).
c) the useful power of the motor (R: ##334\, \textrm{W}##).
Ohm's law
The current of the circuit would be:
$$I=\dfrac{\varepsilon - \varepsilon'}{r+r'}=\dfrac{100-\varepsilon'}{1+r'}$$
But I do not understand the two methods of operation of the engine that the statement talks about: it rotates in normal regime and the engine is prevented from turning. What conclusions could I draw from this?
When the motor is prevented from rotating, it acts as a simple resistor.
When the motor is rotating, it acts as a simple resistor and an emf-source in series.
You might find it useful to draw the two circuits.
Likes Tomy World, berkeman and Guillem_dlc
Thank you very much! With this hint I was able to do the exercise and I got what it says.
Likes berkeman and Steve4Physics
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
