- #36
rcgldr
- 8,875
- 637
When walking, the person is not trying to move the Earth (it only moves a very very tiny amount), but on a bike the person is trying to lean the bike and get the tires to exert a force onto the pavement, which will result in the pavement exerting a force back onto the tires. As previously posted, in some scenarios, the forces between tire and pavement will be in the "wrong" direction, and in other scenarios, even when these forces are in the "right" direction, the rider ends up leaning the wrong way.Erunanethiel said:The Earth is much heavier than us too, why doesn't it pose a problem when we push against it when walking but it does when trying to apply a horizontal force on the pegs is what I don't get.
The system of bike and rider are a unitrack system, for a coordinated turn, the system first has to be leaned in the desired direction of turn before it actually can be turned in that direction. In some cases, an uncoordinated turn maneuver can be used to avoid potholes: say a bike is headed towards a pothole, and rather than trying to do a normal turn away from the pothole, the rider uses "pro-steer" to steer the tire contact patches around the pothole, and after passing the pothole, steers the other way to return the bike back to vertical. For example, the rider steers right to cause the tires to go around the right side of the pothole, while the bike ends up unbalanced leaning to the left. The rider delays correcting the left lean until after the bike passes the pothole. The advantage of this is that there's no delay waiting for the bike to lean to the right before turning to the right.
