Hondaboi1729
I don't know if it's the same for a car but bikes uses a starter relay to set off a starter motor which cranks the engine.
Bikes have a side stand for you to lean the bike against when stationary. In case the rider tries to start the bike with side stand deployed (could cause crash if forget to lift up out of the way when cornering the bike) there is a side stand switch to cut off the ground to the starter relay if stand down.
In conjunction there is a clutch switch in series to prevent being started in gear. there is also a neutral switch in parallel to these two connected to ground so the bike can be started in neutral even if the side-stand is deployed
i.e side stand switch off (open)
But in every bike there's a diode below in the pic:
Basically as far as I can see the way each switch works is when it's open it cuts off the ground to the coil in the starter relay.
So either neutral switch is closed or BOTH clutch and sidestand switches are closed for current to be flowing into the relay...
Now I really can't see what difference would be made if you deleted that diode (presumably to protect the switches from backwards current). But I mean why on Earth would current go back the wrong way to potentially damage the switches? Is it something to do with the collapse of the magnetic field causing current to try and flow the other way when the starter button is released (since no more current to +ve so relay so field collapses)? Just a suggestion here- I'm asking not telling- I've no idea
IF this was the case though, then why is there no diode to the fuel pump relay, the cooling fan relay and any other kind of relay on the bike?
Also I've just thought- they're just bloody switches so unpolarised so why would the direction of the current matter- it makes less sense to me what this component does...
Edit I think I'm missing another diode to the clutch and sidestand switches in the diagram sorry.
