Movement of the water level in the barrel - calculate its velocity, etc.
In summary, the text discusses the dynamics of water movement in a barrel, focusing on how to calculate the velocity of the water as it flows out. It likely includes principles of fluid mechanics, such as the relationship between water level, pressure, and flow rate, along with relevant formulas and examples to illustrate the calculations involved.
Lotto
246
The barrel of a cylindrical shape containing the ##A_1## cross-section has a discharge hole in the bottom containing the ##A_2## cross-section. ##A_1## is much bigger than ##A_2##. Water's coming out through the opening. At time ##t_0 = 0##, the level has a height of ##h_0## above the bottom of the barrel.
Calculate the level's velocity as a function of time, its acceleration and the time when the barrel is empty.
##A_1 \frac{\mathrm d h}{\mathrm d t}=-A_2\sqrt{2hg}##
Here is only my solution:
##A_1 \frac{\mathrm d h}{\mathrm d t}=-A_2\sqrt{2hg}##,
so by integrating we get
##h(t)=\left(\sqrt{h_0}-\frac{A_2}{2A_1}\sqrt{2g} t\right)^2.##
Setting ##h(T)=0## we get
##T=\frac{A_1}{A_2}\sqrt{\frac{2h_0}{g}}.##
By doing the first time derivative of ##h## we get
##v(t)=\frac{{A_2}^2}{{A_1}^2}gt-\frac{A_2}{A_1}\sqrt{2h_0 g}.##
##v(t)## has negative value because it points downward.
By doing the first time derivative of ##v## we get
##a(t)=\frac{{A_2}^2}{{A_1}^2}g.##
It is correct? Is there an "easier" way to solve it?
Lotto said:
Homework Statement: The barrel of a cylindrical shape containing the ##A_1## cross-section has a discharge hole in the bottom containing the ##A_2## cross-section. ##A_1## is much bigger than ##A_2##. Water's coming out through the opening. At time ##t_0 = 0##, the level has a height of ##h_0## above the bottom of the barrel.
Relevant Equations: ##A_1 \frac{\mathrm d h}{\mathrm d t}=-A_2\sqrt{2hg}##
Procedurally it looks ok to me. I haven't checked the math in every part to final result(but they look reasonable). The criterion ##A_1 \gg A_2## neglects acceleration of the fluid body inside the barrel. Also, in reality at ##t = 0 , v = 0 ## which is not reflected in the simplification. As for a simpler method, not that I know of.
Likes Lotto
The time derivative doesn't look right. Remember the chain rule.
Likes MatinSAR
I think it is right. I calculated it again and got the same result.
Likes erobz
Yes, it is right. I initially misread ##t## as being under the radical, but that would make the expression dimensionally incorrect. Sorry about the confusion.
Likes MatinSAR
The Bernoulli equation you started with is for steady flow, so no acceleration of the flow over time Yet you find there is an acceleration. Also, it is evident that the downward acceleration cannot be constant. It will decline as the level drops, eventually being negative.
This is, in fact, a very difficult problem. See posts #17, #19 at https://www.physicsforums.com/threads/velocity-of-efflux-out-of-a-water-tank.868030/#post-5455954. It is unlikely there is a closed form for the motion as a function of time.
Likes erobz and MatinSAR
haruspex said:
The Bernoulli equation you started with is for steady flow, so no acceleration.
Perhaps just a clarification for the OP: "convective" acceleration is fine in Bernoulli's i.e. flow can accelerate along a streamline depending on pipe geometry. "Steady flow" in this case means the flow velocity at any fixed position along a streamline is not changing in time. The latter is the criterion @haruspex is saying it fails.
Likes MatinSAR and haruspex
Thanks, I've clarified it.
I have a question about this. I understand that the steady flow Bernoulli equation is not applicable here. The link provided by @haruspex in @Chestermiller's post #6 has the equation $$g h(t)=\frac{v_x^2(t)}{2}\left[1-\left(\frac{a}{A}\right)^2\right]+h(t)\frac{a}{A}\frac{dv_x(t)}{dt}\tag{9}.$$ The first term is what gets from the steady flow Bernoulli equation. In this problem we are told that ##A_1<<A_2## which translates to ##a<<A##. Why can we not ignore the second term relative to the first in Equation (9) and proceed with the solution? In other words, use the approximation that the steady flow form of Bernoulli's equation is applicable when the area of the exit orifice is much smaller area than the tank's area. It might be a simplifying approximation to a complex situation, but so is ignoring air resistance in projectile motion.
I think you can ignore it under the assumption ##A_1 \gg A_2## ( ##A_1## is the barrel cross section, ##A_2## the hole ) just as you say. Maybe I didn't state that clearly when I brought it up, but my only objection was just to make note that the time varying flow was not strictly valid. I felt it was somewhat "hand wavy" to use that model for this type of problem without mentioning it.
Likes kuruman
True, but as I noted in post #6, the acceleration cannot be constant. There must an initial downward acceleration, but later it is upward. The equations at the link I posted shed no light on this; when the velocity is zero the starting equation collapses to 0=0. If I model the equation obtained for the velocity, at ##h=h_0## it produces zero, so nothing moves.
Consider a thin element of water right at the exit when the hole appears. It is suddenly subject to a non infinitesimal pressure difference. This impulse should produce an 'instantaneous' velocity of ##\sqrt{gh_0}##. Incompressibility implies the surface of the tank water instantaneously acquires a downward velocity of ##\frac aA\sqrt{gh_0}##. It would seem that a full understanding would involve e.g. the speed of sound in water.
But that kick-start is enough. Modelling the equations from there, for a<<A, the tankwater acceleration immediately settles down to ##\frac{a^2}{A^2}g## upwards, as found in post #1.
There is another change in behaviour when the tank is nearly empty. The model says the upward acceleration starts to increase, even for a<<A. This adds roughly ##\frac 12\sqrt{\frac {h_0}g}## to the time to empty. However, the model would be inaccurate there anyway since we would now have horizontal flows in the tank converging on the exit.
I've solved this numerically for a bottle rocket thrust not too long ago. In that problem the heavily transient phase is over quite rapidly, but then again, the entire ejection is over quite rapidly too.
I can't set ##P_o## to 1 atm, because of my gas expanding to vacuum (relative to atmospheric) due to the sealed top, but if I change ## D_b## to 200 cm so that it 2 orders of magnitude than the nozzle diameter, the graphs are approaching each other very rapidly. How significant it is surely depends on the actual dimensions of the hole and barrel which we know nothing about.
FAQ: Movement of the water level in the barrel - calculate its velocity, etc.
What factors influence the movement of the water level in a barrel?
The movement of the water level in a barrel is influenced by several factors, including the rate of water inflow, the rate of water outflow, the dimensions of the barrel, and external forces such as wind or vibrations. Additionally, the initial water level and any changes in these variables will also affect the water level movement.
How do you calculate the velocity of the water level change in a barrel?
The velocity of the water level change in a barrel can be calculated using the equation of continuity and Bernoulli's principle. For a simple scenario where water is draining through an orifice, Torricelli's law can be applied: \( v = \sqrt{2gh} \), where \( v \) is the velocity, \( g \) is the acceleration due to gravity, and \( h \) is the height of the water column above the orifice.
What is Torricelli's law and how is it applied to water flow in a barrel?
Torricelli's law states that the speed \( v \) of efflux of a fluid under the force of gravity through an orifice is given by \( v = \sqrt{2gh} \), where \( g \) is the gravitational constant (9.81 m/s²) and \( h \) is the height of the fluid above the opening. This law is applied to determine the exit velocity of water flowing out of a barrel through a hole or spout.
How does the shape and size of the barrel affect the water level movement?
The shape and size of the barrel significantly affect the water level movement. A larger barrel will have a slower rate of water level change for a given inflow or outflow rate compared to a smaller barrel. The shape, whether cylindrical, conical, or another form, influences the distribution of water pressure and flow dynamics, affecting the velocity and pattern of water level changes.
How can external factors like temperature and pressure impact the water level movement in a barrel?
External factors such as temperature and pressure can impact the water level movement in a barrel. Temperature changes can affect the density and viscosity of water, altering flow rates. Atmospheric pressure variations can influence the pressure differential driving water in or out of the barrel. Additionally, thermal expansion or contraction of the barrel material can change its volume, indirectly affecting the water level.
