Moving along a current carrying conductor
In summary, if you move in the direction of the drift velocity of the electrons in a current carrying conductor, current will be the same. If you move near the speed of light, then both electrons and ions are moving backwards in your frame of reference at close to the speed of light.
quawa99
67
What will happen if I move in the direction of drift of the electrons in a current carrying conductor?
What would happen if my speeds are equal to the drift velocity and in a second case close to the speed of light
Lets say the electrons are moving at v in the conductor frame and the ions are not moving. If you move at v, then the electrons are not moving in your frame, but the ions are moving at -v, so the current is the same.
If you move near the speed of light, then both electrons and ions are moving backwards in your frame of reference at close to the speed of light. It is necessary to transform the 4-current, which is
##J^\alpha = (c \rho, j)##
What is the four-current in the frame moving at v/2?
Assume total charge in this frame is 0.
The current is -nv/2 - nv/2
so the four-current is
##J_1 = (0, -nv)##
Let u = your velocity relative to the frame moving at v/2.
Using Lorentz transformation,
##J_2 = (\gamma uvn/c, \gamma nv)##
The current density is much greater in your frame, by a factor of ##\gamma##, and there is a charge density as well. But the length of the conductor will also be contracted by a factor of ##\gamma##, so the total current is the same. In this frame, there will be an electric field as well as a magnetic field.
You can look at it two ways. The electric field arises from a Lorentz transformation of the magnetic field in the original frame. Or the electric field arises from the charge which results from a Lorentz transformation of the current in the original frame. Same thing.
Likes 1 person
Put it simpler:
Since the drift velocity is typically much smaller than lightspeed in the frame of the wire, you wouldn't see big effects from the difference between the speeds (moving charges and wire) in your frame.
The usual way to treat these problems is to model the wire as two lines of charges... decide on a frame of reference and the charge densities in that frame.
Very important - if "you" are the observer, do not talk about "you" moving.
Everything else is moving. "You" are always stationary.
Reword the question with these things in mind and you should find it easier to cope with.
Likes 1 person
FAQ: Moving along a current carrying conductor
How does a current carrying conductor create a magnetic field?
As electrons flow through a conductor, they create a circular magnetic field around the conductor. This is due to the movement of the negatively charged electrons, which creates a force perpendicular to the direction of the current flow.
How does the direction of current flow affect the magnetic field?
The direction of the magnetic field is determined by the direction of the current flow. If the current flows in one direction, the magnetic field will be in a clockwise direction. If the current flows in the opposite direction, the magnetic field will be in a counterclockwise direction.
How does the strength of the current affect the magnetic field?
The strength of the magnetic field is directly proportional to the strength of the current. This means that the stronger the current, the stronger the magnetic field will be.
What is the right-hand rule for determining the direction of the magnetic field?
The right-hand rule states that if you point your thumb in the direction of the current flow, your fingers will curl in the direction of the magnetic field.
How can the magnetic field be used to move a conductor?
If a current carrying conductor is placed in a magnetic field, it will experience a force due to the interaction between the magnetic field and the current. This force can be used to move the conductor, and is the principle behind electric motors and generators.
