Moving applications to external SSD....
  • Thread starter Thread starter fog37
    Applications Ssd
When considering the use of an external SSD for storage, it's important to understand the implications of moving applications versus data. SSDs have limited write and read cycles, and filling them completely can lead to performance degradation due to the wear-leveling algorithm, which requires space to manage file updates efficiently. Therefore, it is generally recommended to keep applications on the SSD for faster startup times while storing larger data files on a traditional hard drive. The speed of the USB connection to the external SSD also plays a crucial role; slower USB ports can limit the SSD's performance. Running benchmarks can help determine which files should be stored on the fastest device. Additionally, using an external SSD may present challenges if it is not always connected, potentially complicating access to applications. Overall, separating data and applications for efficiency is a sound strategy, but internal SSD upgrades could have been a more effective solution for long-term storage needs.
fog37
TL;DR Summary
Moving applications or data to external SSD
Hello everyone,
My pc is getting too full so I got an external SSD (1Tb). Would you suggest moving all the applications on the external SSD or keep them on the pc's hard disk? If so why? Or should I only move all the "data" to the external SSD? What is your recommendation?
Thank you!
Technology news on Phys.org
Interesting question. SSDs have more limited RW statistics. I've read where it's a bad idea to completely fill up an SSD because further RW actions will begin to degrade the disk if the files can't be moved around on it.
Basically, you want to let the SSD wear-leveling algorithm write a file that's been updated to a new area of the SSD spreading around the write action so as not to use the same cells over and over again. On a full SSD that might not be possible.
https://techmonitor.ai/techonology/data-centre/how-long-do-ssds-really-last
Considering that to be the case then perhaps placing data on a magnetic harddrive and application software on the SSD is a better option. You get faster application startup without too much SSD degradation.
Likes fog37 and berkeman
SSDs are much faster than hard disks. But you said "external" I assume that means USB. USB ports come in many different speeds. If it is slow, it may limit the effective speed of the SSB.
You should run your own benchmark. Then assign the files you need fastest to the fastest device. For me, that means the Windows files for booting. Boot-up is much faster with the SSD.
Likes fog37 and russ_watters
Also, unless your external is always plugged in, it can be a pain to use those applications.
Water under the bridge, but replacing the internal may have been better.
Likes fog37 and Wrichik Basu
Thanks. The SSD is an extra external drive I got to separate data from application in an attempt to be more efficient...
That's usually the better plan.
I take it you're still running out of space?
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
