jackfrost1031
- 4
Insulated piston-cylinder device contains 5L of saturated liquid water at constant pressure of 175kPa. Water is stirred by a paddle wheel. A current of 8A flows for 45 minutes through a resistor in the water.
If 1/2 of the liquid is evaporated during the constant pressure process and the paddle wheel work is 400kJ determine the voltage of the source.
V=IR
v_avg = v_f + X*v_fg
Wboundary = integral(P*dV)
There is no heat loss so no Q_out
I took 1/2 of the liquid evaporating to mean that quality, X is 1/2.
The energy balance would be Q - W = dU + dKE + dPE. KE and PE are both zero.
Electrical work is V*I*t
This is constant pressure so Wboundary = P*(V_1 - V_2)
So, with all this summarized I -think- I get.
V*I*t + P(V_1 - V_2) + 400kJ = U_2 - U_1
To get U_2 and U_1 I looked in my property table for saturated water at 175kPa
U_1 is 487 kJ/kg
I used U_avg = U_f + X*U_fg to find U_2
U_2 = 487 + 0.5 * 2038
U_2 = 1505 kJ/kg
So I am stuck with some unit of kJ/kg. How do I get rid of these kg^-1? I'm guessing I do something with v (specific volume) based on how many liters of water I have.
I also need the Volumes.
Could someone help? Thank you
