Moving Schwarzschild Black Hole
In summary, it is possible to adjust the Schwarzschild metric to a form involving three rectangular coordinates. Alternate coordinate systems are also listed, and it is possible to globally transform the coordinates via a Lorentz boost. However, using PPN coordinates is an approximation method that makes further approximations.
Andrew Kim
The Schwarzschild Metric (with ##c=1##),
$$ds^2 = -\Big(1-\frac{2GM}{r}\Big)dt^2+\Big(1-\frac{2GM}{r}\Big)^{-1}dr^2+r^2d\Omega^2$$
can be adjusted to a form involving three rectangular coordinates ##x##, ##y##, and ##z##:
$$ds^2 = -\Big(1-\frac{2GM}{R}\Big)dt^2+\Big(1-\frac{2GM}{R}\Big)^{-1}\big(dx^2+dy^2+dz^2\big)$$
where ##R=\sqrt{x^2+y^2+z^2}##.
Is it possible for one to transform to coordinates that are boosted in the direction of one of the aforementioned coordinates, like one can do with the Minkowski spacetime? (In these coordinates, the black hole would be moving.)
Yes, any coordinates can be used.
There's good news and bad news. The good news is that there are some well-accepted coordinate system that's similar to what you wrote. The bad news is that they are not exactly the same as what you wrote.
If you look at https://en.wikipedia.org/wiki/Schwarzschild_metric#Alternative_coordinates, you'll see the isotropic coordinates listed as one of the "alternate coordinate systems", with a line element of:
$${\frac {(1-{\frac {r_{s}}{4R}})^{{2}}}{(1+{\frac {r_{s}}{4R}})^{{2}}}}{dt}^{2}-\left(1+{\frac {r_{s}}{4R}}\right)^{{4}}(dx^{2}+dy^{2}+dz^{2}$$
It might not be obvious why it's a very good idea to have the speed of light be isotropic, but it is. Basically, if your coordinates don't respect the isotropy of the speed of light, your physics when expressed in those coordinates won't respect isotropy either, the "laws of physics" in coordinate form willl be different in different directions, which is rather confusing.
It also won't be possible to globally transform the resulting coordinates via a Lorentz boost, though. It will be possible to locally transform a "frame field" via a Lorentz transform, though. Techniques for transforming coordinates do exist, but you can't do a global coordinate transform via a Lorentz boost. One way of doing a transform is using algebra and the chain rule, i.e noting that d (x*y) is x*dy + y*dx. But I don't have tome to get into the necessary details.
If you have the background, you might look up PPN coordinates. They are part of an approximation method that is widely used in weak field situations, they are based on the isotropic coordinates I mentioned but make further approximations.
Anyway, if you are willing to go to enough effort, you can eventually do something like what you think you want to do, but usually by the time you figure out all the little details of how to do it correctly, you realize that you don't really want to turn a nice, easy-to-work with stationary metric into a harder-to-work with one where the metric coefficients vary with time.
Likes Mr-R
Maybe it's a stepping stone towards calculating the metric for two colliding black holes.
Related to Moving Schwarzschild Black Hole
What is a Schwarzschild black hole?
A Schwarzschild black hole is a theoretical object in space that is formed when a massive star collapses in on itself. It is characterized by its event horizon, the point of no return, and its singularity, a point of infinite density.
How do Schwarzschild black holes move?
Schwarzschild black holes do not move in a traditional sense, as they are stationary objects in space. However, they can appear to move due to the curvature of space-time around them.
Can a Schwarzschild black hole change direction?
No, a Schwarzschild black hole cannot change direction as it is a stationary object. However, it can appear to change direction when observed from different vantage points due to the warping of space-time around it.
What happens when a Schwarzschild black hole collides with another object?
When a Schwarzschild black hole collides with another object, it can merge with it, causing a larger black hole to form. This is known as a black hole merger and is predicted by the theory of general relativity.
Can a moving Schwarzschild black hole affect nearby objects?
Yes, a moving Schwarzschild black hole can affect nearby objects through its gravitational pull. Any object that comes within its event horizon will be pulled towards the black hole and potentially be consumed by it.
