Moving the graph to the right -- What do you think?
  • Thread starter Thread starter 0kelvin
    Graph
The discussion focuses on the concept of graph translation in calculus, particularly how moving a function to the right or left is represented mathematically. The user explores the implications of the transformation f(x - n) and relates it to composite functions, emphasizing the connection between graph equations and their translations on the x-y plane. An example is provided using a piecewise function to illustrate how the transformation affects the function's output. Additionally, a physics analogy is drawn with wave disturbances, demonstrating how a function can represent a traveling wave. Overall, the discussion seeks to deepen the understanding of graph translations beyond standard textbook explanations.
0kelvin
I'm studying calculus alone with textbooks. The part about moving the graphs to the right or to the left struck me because they just have a list of rules, properties and make you relate the graph with the corresponding equation. I know what is the rate of change and I thought I could do better than the textbook.
I vectorized this to explain why: f(x - n) moves the parabola to the right.
Not satisfied I though. f(x - 2) does remind me of the concept of a composite function. Can I draw something to explain this and relate it to the rate of change?
Likes mcastillo356
Mathematics news on Phys.org
With a graph described with an equation ##f(x,y)=0## given, another graph
f(x-a,y-b)=0
is a translation of that graph with vector (a,b) on x-y plane. For an example say (0,0) is on the original graph, it is translated to (a,b) on the new one.
Take a function that is zero everywhere except the origin:$$f(x)=\begin{cases} 1 & x = 0 \\ 0 & x \ne 0 \end{cases}$$Now define ##g(x) = f(x -2)##. Note that ##g(2) = f(0) = 1##, hence:$$g(x)=\begin{cases} 1 & x = 2 \\ 0 & x \ne 2 \end{cases}$$And we see that ##g(x)## is ##f(x)## moved to the right.
Likes mcastillo356
Here's a related example from physics: a traveling wave disturbance on a string.
Suppose a disturbance has a profile F(x) along a string.
[In physicist's notation...]
F(x-vt) describes that disturbance translating (traveling without distortion) to the right with constant velocity v.
At t=0, consider the disturbance at the string location x=1: F(1).
After a time t, F(1)=F(x-vt) where 1=x-vt.
Since t increases, x must increase to keep x-vt=1. (Indeed, x=vt+1.)
...and similarly for other locations.
Thus, the disturbance moves to the right.
See https://www.desmos.com/calculator/bjt6dleg5h
from
https://www.physicsforums.com/threa...mean-in-the-wave-equation.836348/post-5254546
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
