MHB Mr.Ask's question at Yahoo Answers (Two variables, domain and range)
The function f(x,y) = 1/√(16 - x² - y²) is defined only when 16 - x² - y² > 0, which corresponds to the domain being the open disk D((0,0),4). Therefore, the domain of f is the set of all points (x,y) such that x² + y² < 16. The range of the function varies from 1/4 to infinity, with 1/4 included and infinity excluded. Thus, the range is [1/4, +∞). This analysis provides a clear understanding of the function's domain and range.
Fernando Revilla
MHB
Mathematics news on Phys.org
Hello MrAsk,
There exists $f(x,y)=\dfrac{1}{\sqrt{16-x^2-y^2}}$ if and only if $16-x^2-y^2>0$ or equivalently if and only if $x^2+y^2<4^2$ (open disk $D((0,0),4)$). That is, $$\boxed{\:\mbox{Dom } (f)=D((0,0),4)\:}$$ On the other hand, for every $(x,y)$ such that $x^2+y^2=r^2$ with $0\leq r<4$ we have $f(x,y)=\dfrac{1}{\sqrt{16-r^2}}$ so, $f(x,y)$ varies from $1/4$ (included) to $+\infty$ (excluded). That is, $$\boxed{\:\mbox{Range } (f)=\left[1/4,+\infty\right)\:}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
