MRI Electromagnet Interference in a Figure-8 cable
In summary: If you are storing the signal cable in a figure-8 configuration, make sure that there is at least 2-3 times the cable length between any points where the cable crosses the figure 8.
Ruumahum
The prevailing wisdom is that coiling excess signal cable under an MRI magnet for storage in a figure-8 configuration will reduce or eliminate induced noise onto the cable from the pulsing fields from gradient coils. I am starting to doubt this, however. A quick diagram of a figure-8 looped cable in a magnetic field doesn't really show me a way to buck the noise effectively. Does anyone have some data to support/disprove this?
Welcome to the PF.
Do you understand how current gets induced in a loop when a changing magnetic field pierces the area enclosed by the loop? Are you familiar with the Right Hand Rule?
Look at how the direction of the Right Hand Rule vector flips for the two sides of the figure-8... :smile:
A figure 8 coil can be effective at reducing pick-up from time-dependent, but spatially uniform, magnetic fields. However, the time-dependent magnetic fields from an MRI machine are not uniform magnetic fields. An MRI machine uses a large constant field, which will not contribute directly to the noise, and many pulsed magnetic field gradient coils. The latter usually are designed to supply a linear gradient of one component of the magnetic field along a certain direction inside the magnet. It is thus quite likely that those fields are also non-uniform outside the magnet. That means that in some circumstances and orientations, a figure-8 coil might actually pick up this noise better than a circular coil.
If you have a figure 8 coil lying on the floor under your MRI magnet and you are getting lots of noise, try rotating the coil (about a vertical axis through the center of the coil). I would start with a 90 degree rotation. Even better, however, is to reduce the amount of cable near your time-dependent magnet fields.
Likes berkeman
Related to MRI Electromagnet Interference in a Figure-8 cable
What is MRI Electromagnet Interference?
MRI Electromagnet Interference occurs when the strong magnetic field from an MRI machine interferes with the electrical signals in a nearby device, such as a figure-8 cable.
How does MRI Electromagnet Interference affect a figure-8 cable?
MRI Electromagnet Interference can disrupt the electrical signals in a figure-8 cable, causing distorted or lost data transmission. It can also cause damage to the cable or the device it is connected to.
Can all figure-8 cables be affected by MRI Electromagnet Interference?
Yes, all figure-8 cables can be affected by MRI Electromagnet Interference. However, the extent of the interference may vary depending on the quality and shielding of the cable.
How can MRI Electromagnet Interference be prevented in figure-8 cables?
To prevent MRI Electromagnet Interference, the figure-8 cable should be shielded with a material that can block the magnetic field. It is also important to ensure that the cable is properly grounded and kept at a safe distance from the MRI machine.
Are there any health risks associated with MRI Electromagnet Interference in figure-8 cables?
There are no known health risks associated with MRI Electromagnet Interference in figure-8 cables. However, it is important to address the interference to prevent data loss or damage to equipment.
  • Electromagnetism
