MSc particle physics revision question - angle of muon from pion decay
In summary, you can solve for the angle at which the neutrino emerges from the decay of the moving pion by using the conservation of energy and momentum, and plotting the result against the angle θ.
BJD
I am trying to revise for PhD, going over MSc work. Could anyone help me with this question?
A pion traveling at speed β(=v/c) decays into a muon and a neutrino, π→μ + [itex]\nu[/itex]. If the neutrino emerges at 90° to the original pion direction at what angle does the muon come off?
[ Answer: tanθ = ( 1 - m[itex]_{\mu}[/itex][itex]^{2}[/itex] / m[itex]_{\pi}[/itex][itex]^{2}[/itex] ) / ( 2βγ[itex]^{2}[/itex] ) ]
→ using particle physics (pp) units:
E[itex]_{\pi}[/itex] = E[itex]_{\mu}[/itex] + E[itex]_{\nu}[/itex] → energy conservation.
[itex]\bar{p_{\pi}}[/itex] = [itex]\bar{p_{\mu}}[/itex] + [itex]\bar{p_{\nu}}[/itex] → momentum conservation. (3 vector)
βγm[itex]_{\pi}[/itex] = |[itex]\bar{p_{\pi}}[/itex]| (speed of light c not included as pp units)
invariant mass squared from decay of the moving pion: m[itex]_{\pi}[/itex][itex]^{2}[/itex] = ( E[itex]_{\mu}[/itex] + E[itex]_{\nu}[/itex] )[itex]^{2}[/itex] - ( [itex]\bar{p_{\mu}}[/itex] + [itex]\bar{p_{\nu}}[/itex] )[itex]^{2}[/itex]
→m[itex]_{\pi}[/itex][itex]^{2}[/itex] = E[itex]_{\mu}[/itex][itex]^{2}[/itex] + E[itex]_{\nu}[/itex][itex]^{2}[/itex] + 2E[itex]_{\mu}[/itex]E[itex]_{\nu}[/itex] - { [itex]\bar{p_{\mu}}[/itex][itex]^{2}[/itex] + [itex]\bar{p_{\nu}}[/itex][itex]^{2}[/itex] + 2[itex]\bar{p_{\mu}}[/itex][itex] \cdot[/itex][itex]\bar{p_{\nu}}[/itex]}
substituting ( m[itex]^{2}[/itex] = E[itex]^{2}[/itex] - p[itex]^{2}[/itex] ) into:
→m[itex]_{\pi}[/itex][itex]^{2}[/itex] = E[itex]_{\mu}[/itex][itex]^{2}[/itex] - p[itex]_{\mu}[/itex][itex]^{2}[/itex] + E[itex]_{\nu}[/itex][itex]^{2}[/itex] - p[itex]_{\nu}[/itex][itex]^{2}[/itex] + 2E[itex]_{\mu}[/itex]E[itex]_{\nu}[/itex] - 2|[itex]\bar{p_{\mu}}[/itex]||[itex]\bar{p_{\nu}}[/itex]|cos ( 90°+θ )
gives:
→m[itex]_{\pi}[/itex][itex]^{2}[/itex] = m[itex]_{\mu}[/itex][itex]^{2}[/itex] + ( m[itex]_{\nu}[/itex][itex]^{2}[/itex] = 0 ) + 2E[itex]_{\mu}[/itex]E[itex]_{\nu}[/itex] - 2|[itex]\bar{p_{\mu}}[/itex]||[itex]\bar{p_{\nu}}[/itex]|( - sin (θ) ) (the mass of the neutrino is taken as zero here)
also as: cos (90+θ) = cos(90) cos(θ) - sin(90)sin(θ) = - sin (θ)
I got stuck a few lines after this, can anyone who understands this help? Am I on the right track with the methodology?
You'll find it more convenient to work with four-vectors. Let ##p_\pi^\alpha = (E_\pi, \vec{p}_\pi)##, ##p_\mu^\alpha = (E_\mu, \vec{p}_\mu)##, and ##p_\nu^\alpha = (E_\nu, \vec{p}_\nu)## be the four-momentum of the pion, muon, and antineutrino respectively, where ##\vec{p}## denotes three-momentum. Conservation of energy and momentum gives you
$$p_\pi^\alpha = p_\mu^\alpha + p_\nu^\alpha.$$ Squaring this yields
$$m_\pi^2 = m_\mu^2 + m_\nu^2 + 2p_\mu^\alpha {p_\nu}_\alpha = m_\mu^2 + m_\nu^2 + 2(E_\mu E_\nu - \vec{p}_\mu \cdot \vec{p}_\nu),$$ which is the same thing you got with a bit more algebra.
Often, the trick to these problems is to rearrange the original equation so that the product of the various four-vectors results in the conveniently placed zero. For example, you know that ##\vec{p}_\pi## and ##\vec{p}_\nu## are perpendicular to each other, so their dot product will vanish. This suggests you try squaring ##p_\pi^\alpha - p_\nu^\alpha = p_\mu^\alpha##.
Thank you vela
FAQ: MSc particle physics revision question - angle of muon from pion decay
What is the angle of a muon from pion decay?
The angle of a muon from pion decay is dependent on various factors such as the energy of the pion, the mass of the muon, and the angle at which the pion decays. This angle can range from 0 to 180 degrees.
Why is the angle of muon from pion decay important in particle physics?
The angle of muon from pion decay is important because it provides information about the weak interaction that occurs during the decay process. It is also used to study the properties of particles and their interactions.
How is the angle of muon from pion decay calculated?
The angle of muon from pion decay can be calculated using the laws of conservation of momentum and energy. It involves measuring the momenta of the particles involved in the decay and using trigonometric functions to determine the angle.
What does a larger angle of muon from pion decay indicate?
A larger angle of muon from pion decay indicates a higher energy of the pion or a higher mass of the muon. It can also suggest a violation of the laws of conservation of momentum and energy, which can lead to further investigation and discoveries in particle physics.
How does the angle of muon from pion decay affect the lifetime of the muon?
The angle of muon from pion decay does not directly affect the lifetime of the muon. However, it can indirectly impact it by affecting the energy and momentum of the particles involved, which can influence the decay process and the resulting lifetime of the muon.
