Multi-Choice Question: Differentiable function
In summary, the Mean Value Theorem states that the slope of the line between two points is equal to the average of the slopes of the lines between the two points.
sergey_le
77
Member warned that some effort must be shown
Let function ƒ be differentiable on interval [0, 1] and ƒ(0) = 0, ƒ(1) = 1.
Which of the following is true?
(Edited)
be f Differentiable function In section [0,1] and f(0)=0, f(1)=1. so:
a. f A monotonous function arises in section [0,1].
b. There is a point c∈[0,1] so that f'(c)=1.
c. There is a point c∈(0,1) where f has Local max.
I have to choose one correct answer.
I don't see what you have done up until now in attempting to find the answer. A good start is to draw such a function, then think about things such as the mean value theorem and similar theorems. Then please post what you have and where you get stuck so that one may go on from there.
such 1 Explains why a is wrong
such 2 Explains why b is wrong
I can't see why b is wrong, so I guess b is the correct answer.
But I can't prove it.
I tried with the Mean value theorem, and it didn't work.
I tried with Darboux's theorem but it didn't work either
I think you have a typo: you probably mean that your diagram (2) is a counter-example to (c).
Try looking at your two graphs; suppose someone tried to use one of them as a "counter-example" to b. Your drawn functions are continuously differentiable in that interval. I'll do (2); for (1), it's similar. At the minimum at x= m, you have f'(m)=0; you also have f'(1)>1. Since the function g(x)=f'(x) is continuous, there must be a k, m<k<1, so that g(k)= f'(k) = 1. So, that counter-example to (b) wouldn't work. I am not saying that this is a proof that (b) is correct, but the counter-counter proof might set you thinking.
Likes sergey_le
Why didn't the mean value theorem work?
Likes nomadreid
sergey_le said:
Homework Statement:: Differentiable function
Homework Equations:: Differentiable function
I had difficulty with the statement of your problem.
It looks like it should be stated somewhat like the following:
Let function ƒ be differentiable on interval [0, 1] and ƒ(0) = 0, ƒ(1) = 1.​
Which of the following is true?​
a.​
b.​
c.​
Is this a correct statement of the problem?
a.​
b.​
c.​
Yes.
My English is not good.
I try to translate my questions into English.
I'm sorry
First off I have a typo. Thanks for noticing. English is not good.
I didn't understand how you know that f'(1)>1 ?
Could you please explain to me?
I think you should look at the Mean Value Theorem.
Likes nomadreid and sergey_le
thank you friend . I'm just trying to figure out how to do it
What does the MVT (Mean Value Theorem) say?
Likes sergey_le
Note that the slope of the line between your endpoints is 1, and then look at the first diagram to the right in https://en.wikipedia.org/wiki/Mean_value_theorem, and then read the caption.
Likes sergey_le
Thanks so much everyone.
I understand
Likes nomadreid
Related to Multi-Choice Question: Differentiable function
1. What is a differentiable function?
A differentiable function is a mathematical function that is continuous and has a well-defined derivative at every point in its domain. In simpler terms, it is a function that can be smoothly drawn without any sharp corners or breaks.
2. How do you know if a function is differentiable?
A function is differentiable if its derivative exists at every point in its domain. This means that the function must be continuous and have a well-defined slope at every point. This can be determined through various methods, such as using the limit definition of a derivative or checking for differentiability using rules and properties of derivatives.
3. What is the importance of differentiable functions in mathematics?
Differentiable functions play a crucial role in calculus and many areas of mathematics. They are used to model and analyze various real-world phenomena and are essential in solving optimization problems. Additionally, the concept of differentiability is fundamental in understanding more advanced topics such as differential equations and multivariable calculus.
4. Can all functions be differentiable?
No, not all functions are differentiable. For a function to be differentiable, it must satisfy certain conditions, such as being continuous and having a well-defined slope at every point. Functions that have sharp corners, discontinuities, or vertical tangents are not differentiable at those points.
5. How is differentiability related to continuity?
Differentiability and continuity are closely related concepts. A function that is differentiable at a point must also be continuous at that point. However, a function can be continuous at a point without being differentiable at that point. In other words, differentiability is a stricter condition than continuity.
