K29
- 108
The curve [tex]p:R->R^{n}[/tex] and the vector [tex]v \in R^{n}[/tex]. Assume [tex]v [/tex] and [tex]p'(t)[/tex] are orthogonal for all [tex]t[/tex]. And that [tex]p(0)[/tex] is orthogonal to [tex]v [/tex].
Prove that [tex]p(t)[/tex] and [tex]v[/tex] are orthogonal for all t.
Since the previous question in the same main question (ie 2(a) and we are now working on 2(b)is the following proof who's result may be relevant.
[tex](u\cdot v)' = u\cdot v' +v\cdot u'[/tex]
[tex]u,v\in R^{n}[/tex]
I can see that this should be true, just struggling with how to prove it:
I've applied the above relation to both the given dot products and set them equal to zero, since they are orthogonal. I've also expanded
[tex](p(t) \cdot v)'[/tex] with the same above relation and I end up with 4 equations which may have been useful:
[tex]v\cdot p'(t)=0[/tex]
[tex]v\cdot p(0)=0[/tex]
[tex](v\cdot p(0))'=v\cdot p(0)'+p(0)\cdot v'=0[/tex]
[tex](v\cdot p(t))'=v\cdot p'(t)+p(t)\cdot v'[/tex]
however I see no way to relate u.v itself(rather than the derivative) using this method. I've substituted the above 4 equations into each other in various ways, however there is a fundamental relationship that I think I am missing that somehow links p(0) to everything else.
I've also tried writing the last two equations as summantions(dot product definition); and as the full matrix that the derivatives would yield, but the result is much the same dead end, other than the fact that I can pull the derivative out of the summations on the left hand side of the equations
Help pls?
