Multichannel analyzer to computer
  • I
  • Thread starter Rajini
  • Tags
    Computer
In summary: The interface box and a CAMAC crate can be found on eBay for about $200.In summary, you need a CAMAC controller, a CAMAC crate, and an interface box to connect your MCA to a computer.
Rajini
621
Dear All,
Can some one help me of how to connect qVt MCA 3001 (from Lecroy) to a personal computer? What is needed for it? and software required after connecting will also be helpful to me.
Thanks and regards, Raj.
Hi, Rajini,
I only have a passing acquaintance with the electronics that you have. Back in the early days of digital nuclear instrumentation before PCs a modular commercial system was introduced in which specific function modules like discriminators , amplifier or MCA could be assemble and mixed and matched together as needed. This was done in what is called a NIM bin,.NIM standing for nuclear instrument module. This is an electronic rack mounted assembly or crate. This standard did not allow for the passing of digital data among the modules. A later standard called CAMAC Computerized Automated Measurement and Control. allows data communication among the modules. A module called a crate controller allowed connection to a computer. From what I have been able to learn from the internet you can use a a Lecroy qvt CAMAC interface to connect your MCA to a computer. However this involves using a CAMAC crate as well. Since I suppose you do not have a crate and may not be able to find a CAMAC controller you would have to build and interface. The Lecroy link above gives spec's of the controller which could be useful for a person to design such and interface or develop a hack for your problem.
Lecroy was bought out by Teledyne and I do not think it still makes MCA or other nuclear instrumentation. Good Luck.
Their website describes pretty much what you need, as Gleem says above it has a CAMAC interface available; and there is another module that plugs into the bus of your PC for direct acqisition on the PC.
FAQ: Multichannel analyzer to computer
What is a multichannel analyzer?
A multichannel analyzer, also known as an MCA, is a device used to measure and record the energy spectrum of radiation. It converts incoming analog signals into digital pulses and sorts them into different channels based on their energy levels.
How does a multichannel analyzer connect to a computer?
A multichannel analyzer can be connected to a computer through various interfaces such as USB, Ethernet, or PCI. The type of connection depends on the specific model of the MCA and the computer's available ports.
What is the purpose of connecting a multichannel analyzer to a computer?
Connecting a multichannel analyzer to a computer allows for data acquisition and analysis. The computer can control the MCA, collect and store data, and perform calculations and visualizations on the data collected.
Can a multichannel analyzer be used with different types of radiation?
Yes, a multichannel analyzer can be used with various types of radiation such as gamma rays, X-rays, and alpha particles. The MCA's settings and parameters can be adjusted to accommodate different types of radiation.
Are there any limitations to using a multichannel analyzer with a computer?
One limitation of using a multichannel analyzer with a computer is the processing power and memory capacity of the computer. If the data collected is too large, it may slow down or crash the computer. Additionally, the computer and MCA must be compatible in terms of communication protocols and software.
