Multichoosing (Stars and bars)
  • Thread starter 22990atinesh
In summary, the notation ##\left(\!\left(n \atop k\right)\!\right)## represents the number of k-element multisubsets of an n-element set. It can be translated into the balls-and-bins problem by creating a bin for each element in the set and placing a number of balls in each bin corresponding to the number of times that element appears in the set. This notation is different from ##\left(\!\left(k \atop n\right)\!\right)##, which represents the number of n-element multisubsets of a k-element set.
22990atinesh
143
Suppose we have 'n' Stars and 'k' bins. We have to distribute 'n' stars in 'k' bins (using k-1 bars) such that bins can be empty. We can do this in ##\binom {n+k-1}{k-1}## = ##\binom {n+k-1}{n}## ways. But Sometimes we use another notation ##\left({{k}\choose {n}}\right)## to represent ##\binom {n+k-1}{k-1}##, Which says 'k multichoose n'. But normally as n > k, then how can we choose more objects from less objects i.e. n from k. So, I think It has to be like this ##\left({{n}\choose {k}}\right)##.
Mathematics news on Phys.org
You always choose (not "multichoose" here!) some objects from n+k-1 objects, which is not smaller than n or k (assuming n,k>0).
The notation [itex]\left(\!\left(n \atop k\right)\!\right)[/itex] means [itex]\binom{n+k-1}{k}[/itex].
The reason for this notation is that [itex]\binom{n}{k}[/itex] counts the number of sets of size k drawn from a universe of size n, whereas [itex]\left(\!\left(n \atop k\right)\!\right)[/itex] counts the number of multisets of size k drawn from a universe of size n.
Yes, [itex]\left(\!\left(n \atop k\right)\!\right)[/itex] is positive even when k > n. This makes sense, because you can pick a multiset that is larger than the original set.
I understand that ##\binom{n}{k}## counts the number of sets of size k. But I'm not getting what does ##\left(\!\binom {k}{n}\!\right)## represents. Can you please elaborate.
It counts the number of multisets of size k. A multiset is an object like a set, except that elements can appear more than once. The elements are required to be integers between 1 and n.
For example, if n = 3, the multisets of size 2 are {1, 1}, {1, 2}, {1, 3}, {2, 2}, {2, 3}, {3, 3}, and the multisets of size 3 are {1, 1, 1}, {1, 1, 2}, {1, 1, 3}, {1, 2, 2}, {1, 2, 3}, {1, 3, 3}, {2, 2, 2}, {2, 2, 3}, {2, 3, 3}, {3, 3, 3}.
If n=3, the multisets of size 2 (k=2) is ##\left(\binom {k}{n}\right)=\left(\binom {2}{3}\right)=\binom {3+2-1}{3}=\binom {4}{3}=4##. But we are getting 6 multisets {1, 1}, {1, 2}, {1, 3}, {2, 2}, {2, 3}, {3, 3}. :confused:
No. The number of multisets is ##\left(\!\left(n \atop k\right)\!\right)##, not ##\left(\!\left(k \atop n\right)\!\right)##.
Ok eigenperson I agree, If n=3, the multisets of size 2 (k=2) is ##\left(\!\left(n \atop k\right)\!\right) = 6##. If we talk about this in terms of stars and bars, then what does 'n' and 'k' represents here. Can u explain the multi-set example in terms of stars and bars, It will clear my doubt.
Actually I've read this topic like this. Suppose we have 'n' Stars and 'k' bins.
Case I: We have to distribute 'n' stars in 'k' bins (using k-1 bars) such that bins can not be empty. We can do this in ##\binom{n-1}{k-1}## ways.
Case II: We have to distribute 'n' stars in 'k' bins (using k-1 bars) such that bins can be empty. So here we mix 'k' artificial indistinguishable extra stars with original 'n' stars making total of 'n+k' stars and reduce the problem to Case I. Hence there are ##\binom{(n+k)-1}{k-1}## ways to do it which is equal to ##\left(\!\left(k \atop n\right)\!\right)## not ##\left(\!\left(n \atop k\right)\!\right)##.
To count the number of k-element multisubsets of an n-element set using balls and bins, first make a "bin" for each element in the set. (In this case, there are n bins. Your version of the problem uses the notation "k" for the number of bins, which I think is the source of the confusion.) Then put a number of balls in the bin equal to the number of times that element appears in the set. There are allowed to be a total of k balls. It is easy to translate between the multiset problem and the balls-and-bins problem in this way, but make sure you keep "n" and "k" straight.
Since, as you correctly state, the solution to the balls-and-bins problem is ##\left(\!\left(\#bins \atop \#balls\right)\!\right)##, the number of k-element multisubsets of an n-element set is ##\left(\!\left(n \atop k\right)\!\right)##.
FAQ: Multichoosing (Stars and bars)
What is "Multichoosing" or "Stars and Bars"?
"Multichoosing" or "Stars and Bars" is a mathematical technique used to count the number of ways to distribute a certain number of objects into a certain number of groups. It is often used in combinatorics and probability problems.
How does "Multichoosing" work?
The "Multichoosing" technique involves using a visual representation of stars and bars to determine the number of ways to distribute objects into groups. The stars represent the objects and the bars represent the boundaries between the groups. The total number of stars and bars used will determine the number of ways to distribute the objects.
What are some real-life examples of "Multichoosing"?
"Multichoosing" can be used to count the number of ways to distribute a certain number of students into different classrooms, the number of ways to choose a committee with a specific number of members from a larger group, or the number of ways to distribute a certain number of items into different categories.
Are there any limitations to using "Multichoosing"?
"Multichoosing" is limited to situations where the objects are identical and the groups are distinguishable. It also assumes that the order of the objects within each group does not matter.
How can I practice and improve my "Multichoosing" skills?
The best way to practice and improve your "Multichoosing" skills is to solve various combinatorics and probability problems that involve this technique. You can also find online resources or books with practice problems and solutions to further develop your understanding of "Multichoosing."
