I Multicollinearity and Interactions
  • I
  • Thread starter Thread starter fog37
    Interactions
The discussion centers on the concepts of multicollinearity and interaction terms in multiple regression models. Multicollinearity occurs when independent variables are pairwise correlated, affecting regression coefficients but not predictive results. Interaction terms, created by multiplying independent variables, can be included in models regardless of multicollinearity. The relationship between multicollinearity and interaction terms is complex, as they can exist independently. A key question raised is how correlations between variables should influence the decision to introduce interaction terms in regression analysis.
fog37
TL;DR Summary
Hello,
I understand the concept of multicollinearity: when dealing with a multiple regression model with two or more independent variables, some of the independent variables may be pairwise correlated. This does not affect the model in terms of its predictive results but it impacts the regression coefficients and how we interpret the various variables (IVs).
Multiplicative interaction terms can also be included in a linear regression model. Multicollinearity and interactions are disjoint in the sense that a model with interaction terms does not need to have multicollinearity and vice versa (interesting things probably happen when the interaction terms are multicollinear).
That said, in the case of multicollinearity, one independent variable ##X_1## affects the dependent variable ##Y## but another independent variable ##X_2## affect (is correlated) with the first independent variable ##X_1##. Isn't that similar to what interaction does? Interaction means that when one IV changes the dependent variable but there is another IV that changes the first IV...
Thank you!
Terminology confusing: Independence implies no correlation.
Statistical analysis would usually treat the two situations the same way.
In a multiple regression model, ##Y = a_0 +a_1 X_1 + a_2 X_2 + ... + a_n X_n + \epsilon##, the ##X_i##s are called the "independent variables" regardless of whether they are correlated. ##Y## is the dependent variable.
Independence (in probability theory) means no connection and implies no correlation. Your question seems to be about terminology - I am not familiar with the definitions of these terms as you are using them.
According to sources on the web ( including https://aarongullickson.github.io/stat_book/interaction-terms.html )
An interaction term is a variable that is constructed from two other variables by multiplying those two variables together.
With that definition, an interaction term results from a decision about the form of the function that is being fitted to data. This decision need not be based on a correlation between variables. By contrast the correlation (or lack of it) between variables in a model is usually inferred from the data, but does not necessarily cause us to introduce interaction terms (and convert a linear regression model to a nonlinear model).
An interesting (and presumably well studied) question: How should correlations between variables influence our decision about whether to introduce interaction terms in the function we are fitting to the data?
Likes FactChecker
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
