MHB Multiple arrays: Key and value.
The discussion revolves around a coding problem involving two arrays, keysList and itemsList, where the goal is to print values from itemsList corresponding to elements in keysList that are greater than 100. The original code mistakenly divides the values in itemsList by 2, leading to incorrect outputs for some test cases. The user initially achieved partial success but struggled with the last test case. After receiving feedback, they realized the error stemmed from unnecessary division and adjusted their code to directly use itemsList[i]. This correction resolved the issue, allowing the program to produce the expected outputs for all test cases. The conversation highlights the importance of understanding problem requirements and the impact of code modifications on output accuracy.
lypena35
Hello, I am stuck on this question.The bold part is where I am stuck. I was able to get at least 2 out of the 3 test outputs but I can't seem to get the last one. I tired taking out the dividing by 2 but then the first test output doesn't work. Thank you.
Question:
For any element in keysList with a value greater than 100, print the corresponding value in itemsList, followed by a space. Ex: If keysList = {42, 105, 101, 100} and itemsList = {10, 20, 30, 40}, print:
20 30
Since keysList[1] and keysList[2] have values greater than 100, the value of itemsList[1] and itemsList[2] are printed.
This is my code
Code:
import java.util.Scanner;
public class ArraysKeyValue {
   public static void main (String [] args) {
      final int SIZE_LIST = 4;
      int[] keysList = new int[SIZE_LIST];
      int[] itemsList = new int[SIZE_LIST];
      int i = 0;
      keysList[0] = 42;
      keysList[1] = 105;
      keysList[2] = 101;
      keysList[3] = 100;
      itemsList[0] = 10;
      itemsList[1] = 20;
      itemsList[2] = 30;
      itemsList[3] = 40;
[B]
     * for(i=0;i<SIZE_LIST;i++){
         if(keysList[i]>100){
            System.out.print(itemsList[i]/2+itemsList[i]/2+(" "));
[/B]
      System.out.println("");
      return;
This is the test output.
Testing with keysList ={42, 105, 101, 100} and
Your output: 20 30
Testing with keysList ={99, 100} and
itemsList = {14, -11}
Your output:
✖ Testing with keysList ={101, 312, 541, 120, 199, 114, 107, 221, 987, 876} and
itemsList = {1, 2, 17, 98, 75, 96, 3, 492, -14, -11}
Expected output: 1 2 17 98 75 96 3 492 -14 -11
Your output: 0 2 16 98 74 96 2 492 -14 -10
Technology news on Phys.org
Why do you print [m]itemsList/2 + itemsList/2[/m] instead of [m]itemsList[/m]? Where does the problem statement say something about dividing by 2?
I tired it with just the itemsList but I received a error. I now understand the error must have been with another part of my code. The division was only a temporary fix to answer the first two outputs but it was to specific, so I needed a more generic answer. I retyped my portion of the code in and I used the itemsList as you suggested and it worked this time. Thank you very much for your help. I appreciate it.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
