MHB Multiple consists of only 6's and 7's
  • Thread starter Thread starter I like Serena
    Multiple
A number that does not end in 0 or 5 can have a multiple consisting solely of the digits 6 and 7. For example, the number 12 has the multiple 7776. There is a discussion about whether the case of composite numbers multiplied by powers of 2 is adequately addressed. Participants express a desire for a clear solution from the original poster or Satya. The conversation highlights the challenge and complexity of the problem.
I like Serena
MHB
Given a number that does not end in 0 or 5, prove that it has a multiple that consists of only 6's and 7's.
For instance 12 has the multiple 7776.
Mathematics news on Phys.org
The number can be represented by $p * 2^q$ where p is an odd number not divisible by 5 and q is $>=0$
if q is 0 then we need not bother
for q =1 we have 6 divisible by 2(other numbers also but we are not bothered)
for q = 2 we have 76 divisible by $2^2$
we shall prove by induction that there is a sequence of 6 and 7 (not necessarily any order that is divisible by $2^n$
Before that we prove the following
We have $10^n \equiv 2^n \pmod {2^{n+1}}\cdots(1)$
Proof:
$10^n = 5^n * 2^n = \frac{5^n-1}{2} *2^{n+1} + 2^n\equiv = 2^n \pmod {2^{n+1}} $ as $\frac{5^n-1}{2}$ is integer
Now 6 is divisible by 2 and 76 by ${2^2}$
If a number is divisible by $2^n$ then either it divisible by $2^{n+1}$ or remainder when divided by $2^{n+1}$ is $2^n$
if it is divisible by $2^{n+1}$ then add $6*10^{n+1}$ to it to make is divisible by$ 2^{n+1}$ as both terms are divisible by $2^{n+1}$
if it is not divisible by $2^{n+1}$ that is remainder is $2^n$ then add $7*10^{n+1}$ to it to make is divisible by$ 2^{n+1}$ as both terms leave a remainder $2^n$ and sum zero divisible by $2^{n+1}$
so in both cases we have a number consisting of 7 and 6 (n digits) which is divisible by $2^n$
Now coming to the original problem
if it is odd number say p ( that is there is no power of 2) it is not divisible by 5 either(given) then we can have a repunit as solved in https://mathhelpboards.com/challenge-questions-puzzles-28/multiple-consists-only-1s-26528.html#post116789
which is divisible by p . multiplying by 7 or 6 we get the number
if it is even number that is $p*2^n$ where p is odd
we have a number of n digits say m consisting of digits 7 and 6 which is divisible by $2^n$. we have proved the same above
now we choose p numbers $x_1=1 $, $x_2 = 10^n + 1$,$x_3= 10^{2n}+10^n + 1$, $x_4=10^{3n} + 10^{2n} + 10^n + 1 $ so on $x_{p-1} = 10^{p} + 10^{p-1} \cdots + 1 $
dividing by p either one of the remainders shall be 0 say $x_t$ or 2 numbers say $x_a$ and $x_b$ ( with $a > b $shall have same remainder
so $x_a-x_b$ shall be $x_{a-b} * 10^ b$ so $x_{a-b}$ is divisible by p
so one of the $x$ above is divisible by p. multiplying by m we get a number consisting of 7 and 6 which is a multiple of given number
Thank you kaliprasad for a correct solution!
Just a nitpick:
It is instrumental that it has n digits, so I think that should be mentioned beforehand rather than as an afterthought. There are smaller numbers. It's just that the proof by induction won't work on them.
kaliprasad said:
if it is even number that is $p*2^n$ where p is a prime
I don't think the case of $C*2^n$ is covered where C is a composite number.
Just a nitpick:
It is not. In case a smaller number satisfies the case m digit number is is divisible by $2^n$ we can take 1, $10^m+1$, $10^{2m} + 10^m +1$ so on. So n is incidental and not mandatory.
For the record, Satya provided this problem and my previous challenge as well, which he remembered from an old math journal.
Satya, welcome to MHB! :D
My mistake. I should have said p is odd in place of prime. corrected the same
I'm going to sue you for deliberately trying to hurt my brain... (Sweating)
-Dan
-Dan
Easily fixed. Just get your brain into gear lol.
I would like to have a solution from OP/Satya.
Let $N_k$ be a k-digit number that consists only of 6's and 7's, and that is divisible by $2^k$.
Lemma. $N_k$ exists for every $k\ge 1$.
Proof by induction
$N_1=6$ satisfies the condition.
Suppose $N_k$ exists implying that $2^k$ divides $N_k$. Then $N_k \bmod 2^{k+1}$ is either $0$ of $2^k$.
Let
$$N_{k+1}=\begin{cases}6\cdot 10^k + N_k&\text{if } N_k\bmod 2^{k+1}=0\\
7\cdot 10^k + N_k&\text{if } N_k\bmod 2^{k+1}=2^k
\end{cases}$$
Then $N_{k+1}$ consists of only 6's and 7's.
We have that $2^{k+1}$ divides $6\cdot 10^k$.
We also have that $7\cdot 10^k \bmod 2^k =0$. And since $7$ is odd, we must have that $7\cdot 10^k \bmod 2^{k+1} =2^k$.
Therefore $N_{k+1}$ is divisible by $2^{k+1}$.
QED
The actual number can be written as $2^k m$ where $m$ is co-prime with $10$.
Take the $N_k$ from before and additionally define $N_0=6$ (which is divisible by $2^0=1$).
Let $M_n$ be the number formed by repeating $N_k$ $n$ times.
Then $M_n$ is divisible by $2^k$ because $N_k$ is.
If we look at the first $m+1$ numbers $M_n$, by the pigeon hole principle, there must be at least 2 of them with the same remainder modulo $m$, since there are only $m$ different remainders possible.
The difference of those 2 numbers begins with only 6's and 7's, and ends with only 0's.
That is, it is one of the $M_n$ followed by 0's.
So for some $n$ and $\ell$ we have that $M_n \cdot 10^\ell$ has remainder $0$ modulo $m$.
Since $m$ is co-prime with $10^\ell$, we must have that $M_n$ is divisible by $m$.
So this $M_n$ is divisible by both $2^k$ and $m$.
Therefore $M_n$ is a number that consists of only 6's and 7's, and it is divisible by the actual number $2^k m$.
Our solution is very much like yours.
We divided the numbers into 3 categories:
(1) Odd numbers. Use Pigeon hole theorem to prove every such numbers have a multiple that contains only $7$s.
(2) Numbers of the form $2^n$. Use induction. Exactly as yours.
(3) Numbers of the form $C*2^n$. Where $C$ is coprime with $2$ and $5$. From (2) we do know that $2^n$ has such a multiple. Let's say it is $m$. Then prove that at least one of the number from $m$, $mm$, $mmm$, ... $m$ (repeated $C*2^n+1$ times) is multiple of $C*2^n$. This too can be proved using pigeon hole theorem.
These $3$ cases cover all numbers that are not multiple of $5$.
Hence proved. :)
