Multiple Lens System(Objectless and Parallel Rays)
In summary, the conversation discusses the use of a telescope with two convex lenses, the objective lens and the eyepiece. The objective lens has a focal length of 26cm and the distance between the two lenses is 30cm. The question asks for the focal length of the eyepiece, which can be found using the equation 1/f = 1/d(object) + 1/d(image). The conversation also mentions the use of parallel rays and how they converge on the focal point of the objective lens. The final conclusion is that the focal length of the eyepiece is 4cm (30cm-26cm).
JohnGaltis
Consider a telescope composed of two convex lenses, the objective lens and the eyepiece. The objective lens has a focal length of 26cm. Rays parallel to the principle axis enter the telescope through the objective lens and exit the telescope from the eyepiece as parallel rays. If the distance between the two lens is 30cm, find the focal length of the eyepiece.
1/f = 1/d(object) +1/d(image)
I am used to solving questions where rays come from an object and plugging in values. When rays are parallel and doesn't converge, how do I solve such a question? How do I start?
I know the rays entering the objective lens will converge on the focal point(26cm) since they are parallel rays.
Is the focal length of the eyepiece 4cm? (30cm-26cm)
Hello John, :welcome:
According to your relevant equation: yes.
Make a drawing to check this out !
Ah- thank you, ByU.
Related to Multiple Lens System(Objectless and Parallel Rays)
1. What is a Multiple Lens System?
A Multiple Lens System is a collection of lenses arranged in a specific way to form an image of an object. It is commonly used in optical instruments such as microscopes, telescopes, and cameras.
2. What is an Objectless Multiple Lens System?
An Objectless Multiple Lens System is a setup where there is no object present and parallel rays of light are used to form an image. This is commonly seen in telescopes where the distant objects are already parallel to each other.
3. How does an Objectless Multiple Lens System work?
In an Objectless Multiple Lens System, parallel rays of light enter the first lens and are refracted towards a point called the focal point. The second lens then collects these refracted rays and forms an image at the focal point of the second lens.
4. What are the advantages of using a Parallel Rays Multiple Lens System?
The use of parallel rays in a Multiple Lens System can reduce the amount of aberrations or distortions in the image formed. It also allows for a sharper and clearer image to be formed compared to using diverging rays from an object.
5. What are some applications of Multiple Lens Systems?
Multiple Lens Systems have a wide range of applications in various fields such as microscopy, astronomy, photography, and medical imaging. They are used to magnify and enhance images, allowing us to see objects that are too small or too far away to be seen with the naked eye.
