Hotbirdym
- 1
Hi,
I've asked this question on another forum, but no response until now. Maybe I will have a little bit of luck here. So .. I have a problem. I have a set of 8 parameter and I use this parameters in order to compute a measure (I vary each parameter with a step of 50%). I would like to know how these parameters influence the measure, which one has the highest loading on the measure that I must compute.
First I looked at PCA, but now I think this is not for my problem. Why? When I compute the correlation matrix I see that the correlation between parameters is almost 0 ( 1*pow(10, -20) ) which I consider to be 0. If the correlation is 0 then I tend to believe that they are independent so I need to use a different multivariate analysis method. Also, the correlation between each parameter and the measure is quite high, something like 0.50 or -0.70 and thus I conclude that they are high correlated. So I thought of using MLR. Am I right or not?
I think I have too many parameters and I've reduced the ones which have the lowest correlation with the measure (I've chosen the value for this parameters the highest - 100%) and now I have only 5 parameters.
Please correct me if I am wrong on choosing MLR method or suggest me another method to use in order to compute the influence each parameter has on my measure.
Many thanks,
Elena
Many thanks,
Elena
