Multiple sets of linearly independent vectors
In summary, the conversation discusses the problem of calculating the probability of obtaining two sets of linearly independent vectors from a set of binary vectors of length k. The example given is for k = 4 and randomly selecting 7 vectors. The conversation also touches on using combinatorics and probability tree diagrams to find the probabilities, as well as the potential for generating solutions using software. The ultimate goal is to determine the probability of finding a specific selection of vectors that meet the given criteria.
SvS
hallo
I am trying to calculate the probability to obtain 2 sets of linearly independent vectors from a set of binary vectors of length k.
For example:
k = 4, and therefore I have 2^k = 16 vectors to select from.
I want to randomly select 7 vectors (no repetition).
What is the probability that 4 of the selected vectors forms a linearly independent set (4 x 4 matrix with rank 4)
and
the other 3 forms a linearly independent set (4 x 3 matrix of rank 3)? These two sets are viewed independently from each other.
I can calculate the probability of obtaining a single set of linearly independent vectors, but I cannot figure out how to calculate 2 sets at the same time.
Any help would be greatly apprectiated.
Thank YOU
Hey SvS and welcome to the forums.
So assuming your uniform distribution and non-repetition constraint, it seems like you will have a combinatoric problem.
The first thing to do is to figure out the number of different basis you have. Once this is done you can start to either draw up a probability tree diagram or use straight combinatoric arguments to get the probabilities. Since we know that everything is uniform, this is simplified greatly.
So based on this, what do you think the next steps are?
chiro
Thank you for the reply.
As an engineer struggling with these combinatoric problems, I have trouble to follow all the mathematical terms and methods.
Are you referring to the number of linearly independent sets that can be possibly constructed? I have done so.
Next I tried to construct a probability tree diagram to find the worst possible case. I figured that this would be a lower bound on my problem. But I am struggling to generalise this.
I have also tried to determine the number of possible choices of vectors I can select each time; eliminating the linearly dependent vectors as choices. But considering 2 sets, confuses me greatly.
I am unsure if I am clear.
Thank YOU for the help so far
So to clarify you want to do it for n-dimensional vectors (so 2^n possible vectors) with different situations involving a nxk linear system where 0 < k < n+1?
Assuming a uniform distribution, you want a probability if getting a nxk linear system that is linearly independent? Do you actually want to do something with this information?
Also do you want to actually generate the solutions with a software routine?
Hallo
I have 2^k possible vectors (eg: 2^4 = 16) of length k.
I want to select n (where k < n+1) vectors (eg: n = 7). k vectors must form a linearly independent set AND the other (n-k) vectors must also be linearly independent when viewed seperately.
I do not want all the solutions. I simply want to determine what the probability is of finding such a selection in the first 7 packets I choose.
Hallo.
Can somebody please help me with my problem.
If you can just help me with the following piece, I shall be very greatful:
Problem:
How to determine the probability to obtain a set of k linearly independent vectors after n > k random selections. (Vectors are binary of length k.)
Attempt at Solution
I calculated the probability to obtain k linearly independent vectors after k selections. The probability can be calculated by p = ∏[itex]^{n}[/itex][itex]_{i=1}[/itex] (1-2[itex]^{i-1-n}[/itex]).
But this changes as I select more vectors.
Thank YOU in advance
Related to Multiple sets of linearly independent vectors
1. What is the definition of multiple sets of linearly independent vectors?
Multiple sets of linearly independent vectors refer to a collection of two or more sets of vectors in a vector space that are all linearly independent from each other. This means that none of the vectors in one set can be written as a linear combination of the vectors in the other set.
2. Why are multiple sets of linearly independent vectors important in linear algebra?
Multiple sets of linearly independent vectors are important because they allow for a more flexible and powerful representation of vector spaces. They can be used to span higher-dimensional spaces, which is useful in many applications such as data analysis and machine learning.
3. How do you determine if multiple sets of vectors are linearly independent?
To determine if multiple sets of vectors are linearly independent, you can use the following steps:
  • Arrange the vectors in each set as columns in a matrix.
  • Use row reduction techniques to reduce the matrix to its echelon form.
  • If the echelon form of the matrix has a pivot in every column, then the sets of vectors are linearly independent. Otherwise, they are linearly dependent.
4. Can multiple sets of linearly independent vectors be used to form a basis for a vector space?
Yes, multiple sets of linearly independent vectors can be used to form a basis for a vector space. The basis of a vector space is a set of linearly independent vectors that can be used to represent any vector in that space. Thus, by combining multiple sets of linearly independent vectors, we can create a basis for a higher-dimensional vector space.
5. What is the relationship between multiple sets of linearly independent vectors and linear independence?
Multiple sets of linearly independent vectors are a necessary condition for linear independence. In other words, if multiple sets of vectors are linearly independent, then the individual vectors in each set must also be linearly independent. However, the converse is not always true - multiple sets of linearly independent vectors do not necessarily guarantee linear independence of all individual vectors in each set.
  • Linear and Abstract Algebra
