daddydoodle
- 1
Here's the problem :
Air flows in a passage with an initial Mach No. 2. Determine maximum turning angle A for which 3 regular reflections (i.e. no Mach reflection) of the original oblique shock are possible?
Now, what exactly is a mach reflection? Also, what is the minimum Mach number required for a straight attached shock? From what I have read up, I've worked out that the Mach no. between the 2nd and 3rd (last) reflection should be greater than 1 (which I understood minimum mach number required for a straight attached shock). But I'm not quite sure if what I've understood is right. Could anyone clear this up for me?
Also, if I'm right, then we have the initial and the last (before the 3rd reflection) Mach nos. but then, there are too many unknowns in between to solve the problem. How do I go about that?
