sarah786
- 15
I can't find a proof for the multiplicative inverse of complex numbers... can anybody please tell me the proof (i already know what the formula is)
micromass said:If you already know the formule than you're already on the good way. So, I guess the formula you have is [tex]z^{-1}=\frac{\overline{z}}{|z|^2}[/tex].
So the only thing you need to show now is that [tex]zz^{-1}=z^{-1}z=1[/tex]. Just complete the following multiplication:
[tex]zz^{-1}=\frac{z\overline{z}}{|z|^2}=...[/tex]
The multiplicative inverse of a complex number is the number that, when multiplied by the original complex number, will result in a product of 1. It is often denoted as 1/z, where z is the original complex number.
To find the multiplicative inverse of a complex number, you can use the formula 1/z = (a - bi)/(a^2 + b^2), where a and b are the real and imaginary parts of the complex number. Another method is to take the complex conjugate of the original number and divide it by the squared magnitude of the original number.
The multiplicative inverse of a complex number is the number that, when multiplied by the original complex number, results in a product of 1. The reciprocal of a complex number is simply the inverse of the complex number, without the multiplication by 1. In other words, the reciprocal is just the flipped version of the original number.
No, a complex number can only have one multiplicative inverse. This is because the multiplicative inverse is a unique value that is defined by the given complex number. However, a complex number can have multiple reciprocals, as they are simply the flipped version of the original number.
If the imaginary part of a complex number is zero, the multiplicative inverse is simply the reciprocal of the real part of the complex number. In other words, the multiplicative inverse of a complex number with a zero imaginary part is just the inverse of a real number.
