Multiplicity for 3 Dimensional problem
In summary, the conversation discusses finding an expression for the multiplicity of a chain that can move in all possible directions (3 dimensions). The equation for multiplicity is defined as the number of possible states over total states. The conversation then delves into finding the multiplicity for a 1D chain and generalizing it for 3 dimensions. Suggestions are made to use the expansion of (x_r + x_l)^N and raise it to 3N to represent the other possible directions. It is determined that N represents the number of links in the chain and that (x_r + x_l)^N corresponds to the number of directions.
Krazer101
I am having trouble finding an expression for W (multiplicity) for a chain that can move in all possible directions (3 dimensions)
Multiplicity is the number of possible states over total states.
I understand for a chain that can move in 1 dimension (left or right), the multiplicity is N!/(nr!(N-nr)!). N is the number of monomers the chain is made from and nr is the number of links pointing right and nl = N - nr, is the number of links pointing left. I was wondering how to find the multiplicity when the chain can movie in 3 dimensions (6 total directions)?
If I understand the problem correctly, think about this: the multiplicity for your 1D chain is the coefficient of [itex](x_{r})^{n_r}(x_{l})^{n_l}[/itex] in the expansion of
[tex](x_r + x_l)^N[/tex]
Does that suggest anything to you? Any way to generalize this from 2 directions to 6?
Is it possible to raise the expansion to 3N instead of N to illustrate the other possible directions?
Well, remember what N represents: the number of links in the chain. If you did that, you'd be getting an expression for a chain with triple the length.
What in [itex](x_r + x_l)^N[/itex] corresponds to the number of directions?
Oh I see, thank you
Related to Multiplicity for 3 Dimensional problem
1. What is multiplicity in a 3 dimensional problem?
Multiplicity in a 3 dimensional problem refers to the number of possible solutions or states that can exist in a given system. It can also refer to the number of distinct particles or objects in a system.
2. How is multiplicity calculated in a 3 dimensional problem?
In a 3 dimensional problem, multiplicity is typically calculated using statistical mechanics principles. It involves counting the number of possible microstates that can lead to a given macrostate, taking into account factors such as energy and entropy.
3. What is the significance of multiplicity in understanding a 3 dimensional system?
Multiplicity is important in understanding a 3 dimensional system as it provides information about the number of possible configurations or states that the system can exist in, which can help in predicting its behavior and properties.
4. How does multiplicity relate to entropy in a 3 dimensional system?
Multiplicity and entropy are closely related in a 3 dimensional system. Entropy is a measure of the amount of disorder or randomness in a system, and multiplicity represents the number of microstates that can lead to a given macrostate. The higher the multiplicity, the higher the entropy and vice versa.
5. Can multiplicity be applied to all 3 dimensional systems?
While multiplicity can be applied to many 3 dimensional systems, it may not be applicable to all. It is most commonly used in systems with a large number of particles or objects, such as gases or solids, where statistical mechanics principles can be applied. In some cases, other methods may be used to analyze a 3 dimensional system.
