I Multiplying three vector operators
  • I
  • Thread starter Thread starter Kashmir
    Operators Vector
Kashmir
Given vector operators as
$$\mathbf{A} = (A_{1}, A_{2} ,A_{3}) $$
$$\mathbf{B} = (B_{1}, B_{2} ,B_{3}) $$
$$\mathbf{C} = (C_{1}, C_{2} ,C_{3}) $$
I know that for two vector operators $$\begin{equation}
\mathbf{Q} \mathbf{P} = \sum_{\alpha = 1}^{3} Q_{\alpha} P_{\alpha}
\end{equation}$$
What is $$\mathbf{A}\mathbf{B}\mathbf{C}$$ in component form?
\end{equation}$$
You didn't specify what kind of product you are looking at. (There are several.) But from appearances you are doing an inner (or "dot") product.
So
##\displaystyle \textbf{A} \cdot \textbf{B} = \sum_{i = 1}^3 A_i B_i = \lambda##, which is a scalar, so
##\left ( \textbf{A} \cdot \textbf{B} \right ) \textbf{C} = \left ( \begin{matrix} \lambda C_1 \\ \lambda C_2 \\ \lambda C_3 \end{matrix} \right )##
There is also the cross product, but you have to specify which pair you are multiplying first as the cross product is not associative. And finally, there's the tensor product, but that one's easy as there isn't any mixing: ##\textbf{A} \otimes \textbf{B} \otimes \textbf{C}##. There isn't really much of a component form for this, just
##\left ( \begin{matrix} A_1 \\ A_2 \\ A_3 \end{matrix} \right ) \otimes \left ( \begin{matrix} B_1 \\ B_2 \\ B_3 \end{matrix} \right ) \otimes \left ( \begin{matrix} C_1 \\ C_2 \\ C_3 \end{matrix} \right )##
-Dan
\end{equation}$$
I wouldn't write it this way because it is ambiguous. I would write $$\begin{equation}
\mathbf{Q} \cdot \mathbf{P} = \sum_{\alpha = 1}^{3} Q_{\alpha} P_{\alpha}
\end{equation}$$ for clarity. This distinguishes between an operation ##\mathbf{Q} \cdot \mathbf{P}## which takes two vectors and produces a scalar and an operation ##\lambda \mathbf{Q}## which takes a vector and a scalar and produces a vector.
Note that ##(\mathbf{A} \cdot \mathbf{B}) \mathbf{C} \ne \mathbf{A}(\mathbf{B} \cdot \mathbf{C})## and also note that ##\mathbf{A} \cdot \mathbf{B} \cdot \mathbf{C}## does not exist nor does ##\mathbf{A} \mathbf{B} \mathbf{C}##
Likes PeroK and Kashmir
Thank you.
I'm looking for the product which appears as the result of quantisation rule which takes the classical expression to the quantum one.
Suppose the classical quantites we have are $$\mathscr A_1(\mathbf{r,p,t})=\mathbf{r(p.r)}$$
$$\mathscr A_2(\mathbf{r,p,t})=\mathbf{(r.p)r}$$
What will be the quantum operators ##\mathbf A_1##,##\mathbf A_2## corresponding to ##\mathscr A_1## and ##\mathscr A_2##?
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
