Multivariable analog to the total derivative?
In summary: The generalized Stokes theorem states that in a variational problem with more than one variable, the total Hamiltonian is a function of the derivatives of the variational problem variables.
pellman
684
For a single variable we have
[tex]\int_{x_1}^{x_2} f(x) dx = F(x_2)-F(x_1)[/tex]
if f(x) = dF/dx. f(x) is then a total derivative. What is the analog in 3D so that
[tex]\int_V f(\vec{x}) d^3x[/tex]
does not depend on the values of f in the interior of V?
In case there is not a single answer, let me give the context. In the calculus of variations two Lagrangians are equivalent if
[tex]L_2(q(t),\dot{q}(t),t)=\lambda L_1(q(t),\dot{q}(t),t) + \frac{d}{dt}F(q(t),\dot{q}(t),t)[/tex]
where lambda is a constant and F is any function. (That is, their actions are extremized for the same function q(t).) What replaces dF/dt in this equivalency if we have a multi-parameter action
[tex]S=\int L(q(\vec{x}),\partial q(\vec{x}),\vec{x}) d^3x[/tex]
(where [tex]\partial q[/tex] stands for the various partial derivatives of q)?
Is it [tex]\nabla \cdot \vec{F}[/tex] for some vector function F? Or is there more to it than that?
I think you have your terminology wrong. In your first example F is an antiderivative of f and f is the derivative of F.
The total derivative refers to a function of two or more variables, for example f(x, y). The total differential of f in this case is
[tex]df = \frac{\partial f}{\partial x}~dx + \frac{\partial f}{\partial y}~dy[/tex]
If it turns out that x and y are differentiable functions of t, then the total derivative of f looks like this:
[tex]\frac{df}{dt} = \frac{\partial f}{\partial x}~\frac{dx}{dt} + \frac{\partial f}{\partial y}~\frac{dy}{dt}[/tex]
Thanks to both .
Thanks, Studiot
FAQ: Multivariable analog to the total derivative?
What is the multivariable analog to the total derivative?
The multivariable analog to the total derivative is known as the total differential. It is a mathematical concept that describes how a small change in multiple independent variables affects a function's output.
How is the total differential different from the total derivative?
The total differential is an extension of the total derivative to multivariable functions. While the total derivative considers only one independent variable, the total differential considers multiple independent variables and how they affect the function's output.
What is the purpose of using the multivariable analog to the total derivative?
The multivariable analog to the total derivative allows us to understand how small changes in multiple independent variables affect a function's output. This is useful in fields such as economics, physics, and engineering, where multiple factors can affect a system's behavior.
How is the multivariable analog to the total derivative calculated?
The multivariable analog to the total derivative is calculated using partial derivatives. Each partial derivative represents the rate of change of the function with respect to one of the independent variables while holding the other variables constant. These partial derivatives are then multiplied by the corresponding changes in the independent variables and added together to calculate the total differential.
What are some real-world applications of the multivariable analog to the total derivative?
The multivariable analog to the total derivative is used in various fields to understand and model complex systems. In economics, it is used to analyze the effects of multiple variables on markets and consumer behavior. In physics, it is used to study the behavior of multiple interacting particles. In engineering, it is used to optimize systems by understanding the effects of multiple factors on a system's performance.
