Multivariable Calculus: Geodesic problem
In summary, geodesics on a torus can be thought of as the shortest path between two points on the surface and can be calculated using the first fundamental form matrix. The circles t → (c,t) are geodesics, while the circles t → (t,c) are not generally geodesics. To understand geodesics better, visualizations and practice problems can be helpful.
FluffyLlamas
Consider the parametrization of a torus:
[itex] \tau(u,v)=((2+cos(v)cos(u),(2+cosv)sinu,sinv) [/itex]
The distance from the origin to the center of the tube of the torus is 2 and he radius of the tube is 1. Let the coordinates on [itex] \mathbb R^3 [/itex] be [itex] (x,y,z) [/itex]. If [itex] p = \tau(u,v) [/itex] then u is the angle between the x-axis and the line connecting the origin to the projection of p onto the xy-plane. A slice of the torus through the origin and p by a plane perpendicular to the xy-plane cuts out two circles on the torus, one of which contains p. The angle v is the angle from the center of the circle containing p out to p.
(a) Compute the first fundamental form matrix for [itex] \tau [/itex]
(b) Find the lengths of (1,0) and (0,1) as elements of the tangent space at an arbitrary point (u,v). Explain the varying of these lengths by appealing to the picture above (textbook has a picture of a torus).
(c) What is the angle between (1,0) and (0,1) as elements in the tangent space at an arbitrary point (u,v)?
(d) Show that the circles [itex] t \mapsto (c,t) [/itex] where c is a constant are geodesics in [0,2∏] X [0,2∏] with the metric induced by [itex] \tau [/itex]
(e) Show that the circles [itex] t \mapsto (t,c) [/itex] where c is a constant are not generally geodesics. When are they?
I can't really think of any relevant equations, but the question itself is in this PDF:
http://people.reed.edu/~davidp/homepage/211.pdf
Problem is Chapter 6, #3 (Page 130)
Of course, throughout chapter 6, there are some definitions and such. I'll edit this post to include them if wanted.
Notes, from prof. on geodesics is here: http://people.reed.edu/~davidp/211.2012/lectures/41lecture.pdf
And this is a first semester multivariable calculus class for reference.
So, I understand a-c, completed them, no trouble, I'll still write out my answers below (and edit with the work for them if necessary). But I missed the lecture on geodesics due to illness, and neither the textbook or notes that the professor puts up online aren't particularly helpful. I'm less worried about the specific problem and more about understanding geodesics themselves, so it's a more general question, I guess.
(a)
[itex] \mathbb I =
\begin{pmatrix}
(cos(v)+2)^2 & 0\\
0 & 1
\end{pmatrix}
[/itex]
(b) [itex] |(1,0)|_{(u,v)} = 10 [/itex]
[itex] |(0,1)|_{(u,v)} = (2+cos1)^2 [/itex]
Haven't done the explanation part for this yet, not sure why it's the case. I'll have to think about it some more.
(c) [itex] \theta = cos^{-1} ((3+7cos1)/(10(2+cos1)^2))≈ 1.4655 radians [/itex]
(d) This is where I'm lost. I've read through the notes and textbook many times, and I have no clue where to begin. Could anyone give me a tip on where to begin?
(e) Same as d
Thanks for any help.
I'll be sure to edit this post with my work as I work through it.Hello,
I would like to clarify some concepts before attempting to answer your questions. A geodesic is defined as the shortest path between two points on a curved surface. In the case of a torus, it can be thought of as the path that a string would take if it were stretched tightly around the surface.
Now, let's address your specific questions:
(d) In order to show that the circles t → (c,t) are geodesics, we need to show that they are the shortest path between any two points on the torus. This can be done by using the first fundamental form matrix to calculate the length of the curve and showing that it is minimized when t is constant. You can refer to your textbook or notes for the formula for calculating the length of a curve using the first fundamental form matrix.
(e) To show that the circles t → (t,c) are not generally geodesics, you can use the same approach as in part (d) and show that the length of the curve is not minimized when t is constant. In order for these circles to be geodesics, the torus would have to be a cylinder, where the shortest path between any two points is a straight line. You can also refer to your textbook or notes for more information on this.
In general, to understand geodesics better, I would recommend looking at some visualizations or animations of geodesics on different curved surfaces. This can help to develop an intuition for what they are and how they behave. Additionally, practicing with different examples and working through the calculations can also aid in understanding the concept.
I hope this helps and good luck with your studies!
Related to Multivariable Calculus: Geodesic problem
1. What is multivariable calculus?
Multivariable calculus is a branch of mathematics that deals with studying functions of several variables, and how they change and interact with each other. It involves using techniques from both differential and integral calculus to solve problems in multiple dimensions.
2. What is the geodesic problem in multivariable calculus?
The geodesic problem in multivariable calculus involves finding the shortest path between two points on a curved surface. This path, known as a geodesic, is the equivalent of a straight line in Euclidean space and is determined by the curvature of the surface.
3. How is the geodesic problem related to the study of surfaces?
The geodesic problem is closely related to the study of surfaces, as it involves finding the shortest path between two points on a curved surface. This problem has applications in fields such as physics, engineering, and computer graphics, where understanding the behavior of surfaces is essential.
4. What are some real-world applications of the geodesic problem?
The geodesic problem has many real-world applications, including navigation and route planning, satellite and spacecraft trajectory optimization, and modeling the behavior of light in curved space. It is also used in the design of bridges, pipelines, and other structures where understanding the curvature of a surface is important.
5. Are there any challenges in solving the geodesic problem?
Yes, there are many challenges in solving the geodesic problem, including the complexity of the calculations involved, the need for specialized software and techniques, and the difficulty in visualizing and understanding the behavior of surfaces in multiple dimensions. However, with the advances in technology and mathematics, these challenges can be overcome to solve real-world problems.
  • Calculus
