Multivariable Calculus - Integration Assignment
In summary: So, the rho in the integral becomes r^2*sin(θ)drdθdϕ?In summary, the conversation discusses the process of finding the Jacobian for a problem involving a change of variables and the use of spherical coordinates. The conversation also touches on the concept of moment of inertia and the use of substitutions in integrals.
  • #36
This time I got, (3pi^2 r^4 (a^2 + b^2)abcρ)/8
  • #37
Still not quite. I'm not sure where you are making the error, but it's in there. As a hint, what is the result of doing the first integration inside the big brackets:
$$abc \rho \int_0^1 \int_0^{2\pi} (a^2 cos^2(\theta) + b^2 sin^2(\theta)) r^4 \left[ \int_0^{\pi} sin^3(\phi) \space d \phi \right] d \theta d r$$
  • #38
Doing the first integration I found that,
1/12 (cos(3ϕ) - 9cos(ϕ))
then subbing in ϕ = pi and ϕ = 0
1/12 (cos(3pi) - 9cos(pi)) - 1/12 (cos(0) - 9cos(0)) = 2/3 - (-2/3) = 4/3
  • #39
After that I can integrate for dr,
(a2cos2(θ)+b2sin2(θ))r^5 /5
then subbing in r = 1 and r = 0
(a^2cos^2(θ)+b^2sin^2(θ))/5 - 0 = (a^2cos^2(θ)+b^2sin^2(θ))/5
  • #40
Okay, so now what happens here:
$$abc \rho \int_0^1 \frac{4}{3} r^4 \left[ \int_0^{2\pi} (a^2 cos^2(\theta) + b^2 sin^2(\theta)) d \theta \right] d r$$
Hint: You need to integrate ##cos^2(\theta)## and ##sin^2(\theta)## separately, treating ##a^2## and ##b^2## as constants.
  • #41
Then I can integrate for dθ,
(a^2 θ)/2 + (a^2 sin(2θ)) /4 + (b^2 θ)/2 - (b^2 sin(2θ)) /4
Subbing in 2pi and 0,
(a^2 2pi)/2 + (a^2 sin(4pi)) /4 + (b^2 2pi)/2 - (b^2 sin(4pi)) /4 - ( (a^2 0)/2 + (a^2 sin(0)) /4 + (b^2 0)/2 - (b^2 sin(0)) /4 )
= a^2 pi + b^2 pi
So my final answer is pi(a^2 + b^2)
  • #42
= a^2 pi + b^2 pi
Right, now just clean up the last integration, what do you get?
  • #43
Oh by the way is there a tutorial or like a forum post somewhere on how to format the equations like you do? Makes it a lot easier to read, sorry for typing it out like I am!
  • #44
Oops forgot about abcρ that was outside, so the answer is
abcρ * pi (a^2 + b^2)
  • #45
Why not relax and carefully write the steps out as you did before? Your answer seems to be missing a factor of ##\frac{4}{15}##. Anytime you rush math and forget to write something down, you're going to make a mistake like that.
Also, a useful LaTeX reference is located here:
https://www.physicsforums.com/showthread.php?p=3977517#post3977517
  • #46
Ok I see now, yes I was rushing through things quickly and forgot that I had taken out the 4/3 from integrating dϕ and I had taken out 1/5 after integrating dθ. So that gives me the factor of 4/15.
final answer is now
(4/15) *abcρ * pi (a^2 + b^2)
  • #47
final answer is now
Good. That is indeed the answer and I'm glad you see why.
  • #48
Thanks a lot, thank you for bearing with me all the way through!
