Multivariable temperature variation while swimming in a hot spring
In summary: I have also checked the gradient vector with another online calculator and got the same results. For the second question, I used the formula for the magnitude of a vector in 2 dimensions, which is the square root of the sum of the squares of the vector components.
Poetria
267
42
You are swimming along the surface of a large natural hot water spring. The temperature is hottest near the geothermal heat sources, and cools off inversely proportional to the distance from the heat source as you move away. The hot spring you have found has two heat sources. One is located below x=0, y =0, the other is located x=-10, y=20
Approximation of the temperature:
##T(x,y) = \frac {450} {\sqrt{x^2+y^2+1}}+\frac {420} {\sqrt{(x+10)^2+(y-20)^2+1}}##
You enter the pool at the edge x=20, y=20, where the temperature is 30 degrees Celsius.
What is the gradient of the temperature?
$$\nabla (\frac {450} {\sqrt{x^2+y^2+1}}+\frac {420} {\sqrt{x+10)^2+(y-20)^2+1}})$$
I have computed
##T_x## and ##T_y## and evaluated it at the point (20, 20).
## \frac {-450*x}{x^2 + y^2 + 1)^(\frac {3} {2}} - \frac {420*(x + 10)} {(x + 10)^2 + (y - 20)^2 + 1)^(\frac {3} {2}}, \frac {-450*y}{x^2 + y^2 + 1)^(\frac {3} {2}} - \frac {420*(y - 20)} {(x + 10)^2 + (y - 20)^2 + 1)^(\frac {3} {2}}##
I got [-0.8628, -0.3970]. But it is not correct.
So the answer to the next question: At what rate does the temperature rise per unit distance in that direction?
is not correct:
-2.1732 degrees per meter
Likes Delta2
Poetria said:
Homework Statement:: You are swimming along the surface of a large natural hot water spring. The temperature is hottest near the geothermal heat sources, and cools off inversely proportional to the distance from the heat source as you move away. The hot spring you have found has two heat sources. One is located below x=0, y =0, the other is located x=-10, y=20
I don't think the formula for [itex]T[/itex] is correct. Was that given in the question, or did you have to derive it yourself?
Likes Poetria
This formula was given. I have checked it once more. What's wrong with this equation?
I get the same formula for the gradient, but a different value at (20,20). I get (-0.3745, 0.749). Can you check that calculation? I am not completely confident in my calculations.
Likes Poetria
Of course. Still the same:
-0.862892919050474097014734857686704644880586505653053268225642320
-0.397002951313243437752836778926172651474292918967096802620165023
Perhaps there is a mistake in my formula you haven't noticed. Weird anyway.
I rechecked my calculations and got the same answers you got. (I made reasonable assumptions about some missing parenthesis in the gradient in your post #1.)
Likes Poetria
Thank you very much. :) I need more practice with Latex.
I can't understand why it's marked as wrong. :(
I have decided to continue with the next part of this exercise and it turned out that the value -0.862892919050474097014734857686704644880586505653053268225642320
should be rounded -0.8629 while I have given -0.8628.
And of course the result: -2.1732 degrees per meter is not correct.
It's the gradient's length as the slope of a tangent plane: 0.9498.
Thanks once more for your patience. :)
Likes FactChecker
Yes. I think that your initial value had a little more precision than required. ;-)
  • Haha
Likes Steve4Physics, Poetria and Delta2
I'm curious about what tools you used to do your calculations to that precision.
Likes Poetria
I agree with the vector ##(-0.8628,-0.3970)## for gradient, I calculated it using wolfram.
However the answer to the second question is simply the magnitude of the gradient vector. I don't understand how you calculated -2.1732 degrees per met.
I have used Wolfram Alpha.
Likes FactChecker
