Multivariate Normal Distribution
In summary, The multivariate normal distribution is used to model the probability distribution of a vector of continuous random variables. It is defined by the mean vector and covariance matrix, and has many useful properties, including the fact that any linear combination of the variables follows a univariate normal distribution with its own mean and variance. It is commonly used in statistics and probability theory.
cse63146
452
http://img16.imageshack.us/img16/7703/ass1lx.jpg
I know that [tex]f(x_1, x_2, x_3) = \frac{1}{(2 \pi)^{3/2}|\Sigma|^{1/2}}exp(-\frac{1}{2}x \Sigma^{-1} x)[/tex] since n = 3 and mu = 0.
I've never used the multivariate normal distribution. My prof just derived it, but never taught us how to use it.
so does X1~N(mu,sigma11)?
Yes, although you don't necessarily need it. Here is the useful property you will need for this problem.
Let [tex]\bold X[/tex] be multivariate normal with [tex]\bold \mu=E(\bold X)[/tex] and [tex]\bold \Sigma=Var(\bold X)[/tex].
Then any linear combination [tex]\bold a^T\bold X[/tex] is univariate normal with [tex]E(\bold a^T\bold X)=\bold a^T E(\bold X)[/tex] and [tex]Var(\bold a^T\bold X)=\bold a^T Var(\bold X) \bold a[/tex].
FAQ: Multivariate Normal Distribution
What is the Multivariate Normal Distribution?
The Multivariate Normal Distribution is a probability distribution that describes the joint behavior of a group of variables that are normally distributed. It is often used in statistical analysis to model the relationship between multiple variables.
What are the properties of the Multivariate Normal Distribution?
Some key properties of the Multivariate Normal Distribution include:
  • The distribution is symmetric around the mean
  • The mean, median, and mode are all equal
  • The shape of the distribution is bell-shaped, with most values falling near the mean
  • The total area under the curve is equal to 1
How is the Multivariate Normal Distribution related to the Normal Distribution?
The Multivariate Normal Distribution is an extension of the Normal Distribution to multiple dimensions. While the Normal Distribution describes the behavior of a single variable, the Multivariate Normal Distribution describes the joint behavior of multiple variables. The Normal Distribution can be thought of as a special case of the Multivariate Normal Distribution when there is only one variable.
What are the applications of the Multivariate Normal Distribution?
The Multivariate Normal Distribution is widely used in various fields such as finance, economics, and social sciences. It is used to model the behavior of multiple variables and make predictions based on their joint distribution. It is also used in statistical analysis, machine learning, and data mining to identify patterns and relationships between variables.
How do you calculate the Multivariate Normal Distribution?
The Multivariate Normal Distribution is calculated using the mean vector and covariance matrix of the variables. The formula for the multivariate normal probability density function is P(x) = (2π)^(-k/2) * |Σ|^(-1/2) * e^(-1/2 (x-μ)^T Σ^(-1) (x-μ)), where k is the number of variables, μ is the mean vector, and Σ is the covariance matrix. This formula can be used to calculate the probability of a specific combination of values for the variables.
