Muon Decay: Special Relativity WS#1 Homework
In summary: It may give you a better understanding of the concepts involved.In summary, the muon travels 600 meters before decaying.
relativelnr00
[/B]
1.) A muon is created by a cosmic ray interaction at an altitude of 60km. Imagine that after its creation, the muon hurtles downward at a speed of 0.998, as measure by a ground-based observer. After the muon’s “internal clock” registers 2.0μs , the muon decays?
a.) If the muon’s internal clock were to measure the same time between its birth and death as clock on the ground do (i.e. if special relativity is not true and time is absolute), about how far would this muon have traveled before it decayed?
b.) How far will this muon really travel before it decays?
300m = 300m(1s/3x10^8m) = 10^-6s = 1μs
∆Sab = √∆t^2ab - ∆x^2ab (?)
60km = 200μs
a) If time is absolute:
Muon decays at 600m, or 2μs away from the starting point of 60km, or 200μs (?)
b) 300m = 1μs , thus 2μs = 600m
600m/0.998 = 601.2 m (?)
Anyone have any advice? I'm not looking for the whole solution to be given to me, but I'm at a standstill in terms of my understanding of how the problem works...
Do you know what time dilation is?
I only recently learned what time dilation is, so I'm still very unfamiliar with how the concept works within the math aspect of special relativity. What confuses me most is that the first part of this problem asks for an absolute time version, while the second part asks for something different...
The first question asks you what would happen if there was not time dilation due to special relativity, so of course it will be different.
The second question asks you what happens when special relativity holds, i.e., when there is time dilation. Note that the muon will only decay when 2 microseconds have passed according to its "clock", not the clock in the Earth rest frame.
I'm still unsure about how to approach the first part of the problem, but with the second part:
The muon decays when two microseconds have passed by its clock. It's traveling downwards at a speed of .998, so almost the speed of light. Thus:
2 microseconds = 600 meters
In this case, I'm assuming that dividing by the speed will give me the actual distance that the muon has traveled. Yet something still feels off to me.
Alternatively, should I attempt to plugin the values into the formula ∆Sab = √∆t^2ab - ∆x^2ab?
No, you are computing it with the time elapsed on an Earth clock. This is not what the question asks for. The muon survives until 2 microseconds has passed in its own rest frame.
Orodruin,
I assume then that I just solved for problem a), which assumes that the muon's clock measures the same as one on the ground.
As for problem b, I have no clue where to start. I feel like I may be missing a formula or equation, or maybe it's one I have not learned yet.
I do appreciate the assistance, I'm just not sure where to go next within this problem.
I suggest reviewing that part of your course literature.
FAQ: Muon Decay: Special Relativity WS#1 Homework
What is muon decay?
Muon decay is the process by which a muon, a subatomic particle similar to an electron but with a much greater mass, transforms into other particles through the weak nuclear force.
Why is muon decay important?
Muon decay is important because it provides evidence for the validity of special relativity, a fundamental theory in physics that describes the relationship between space and time.
How does muon decay relate to special relativity?
Muon decay is closely related to special relativity because it involves the concept of time dilation, which is a key principle of special relativity. The shorter lifespan of muons compared to their theoretical lifespan at rest is a direct consequence of special relativity.
What is the significance of muon decay in the study of particle physics?
Muon decay is significant in the study of particle physics because it provides valuable insights into the behavior of subatomic particles and the fundamental forces that govern them. It also helps scientists understand the structure of the universe and the fundamental laws that govern its behavior.
What are some real-world applications of muon decay?
Muon decay has various real-world applications, including in medical imaging techniques such as positron emission tomography (PET) scans. It is also used in particle accelerators to study the properties of subatomic particles and in the development of new technologies, such as muon-catalyzed fusion reactors.
