Muon Time Dilation in Accelerating Frames
In summary: The formula for time dilation still applies in this case, as long as the reference frame is inertial.
bksree
77
Hi
In the book, "Why does E= mc2" by Cox and Forshaw, while discussing time dilation, the example of a muon is given. The authors explain that muons when circulated in the 14 m diameter AGS facility at Brookhaven at 99.94% of the speed of light, its lifetime is increased from the value of 2.2 microseconds (when it is at rest) to 60 microseconds i.e 29 times longer which he explains is equal to gamma = sqrt(1 - v^2 / C^2).
My question is : The formula, gamma = sqrt(1 - v^2 / C^2), is for an inertial system while the muons while moving in the circular orbit are in an accelerating frame. So is it correct to use this expression for time dilation ?
Thank you
Yes. The correct general formula is that the elapsed time for a particle is$$\begin{eqnarray*}
\Delta \tau&=&\int_{t=0}^{\Delta t}d\tau\\
&=&\frac{1}{c}\int_{t=0}^{\Delta t}\sqrt{c^2dt^2-dx^2-dy^2-dz^2}\\
&=&\frac 1{c}\int_0^{\Delta t}\sqrt{c^2-\left(\frac{\partial x}{\partial t}\right)^2-\left(\frac{\partial y}{\partial t}\right)^2-\left(\frac{\partial z}{\partial t}\right)^2}dt
\end{eqnarray*}$$But the sum of the squares of the partial derivatives is just the velocity squared, and hence$$\begin{eqnarray*}
\Delta \tau&=&\frac 1c\int_0^{\Delta t}\sqrt{c^2-v^2}dt\\
&=&\sqrt{1-\frac{v^2}{c^2}}\Delta t
\end{eqnarray*}$$Note that I've said nothing about the path beyond assuming that ##v^2## is independent of ##t## in the last step, but have assumed that the ##t,x,y,z## coordinates are inertial coordinates.
Note that this case is not reciprocal. An observer circling with the muon would not conclude that lab clocks were ticking slow, but that they were ticking fast - the muon observer's frame is not inertial. So, while some results for inertial motion do hold for non-inertial motion, not all of them do.
Likes vanhees71, Dale and etotheipi
The reference frame in which v is measured is an inertial reference frame.
Likes vanhees71
Related to Muon Time Dilation in Accelerating Frames
1. What is muon time dilation in accelerating frames?
Muon time dilation in accelerating frames is a phenomenon in which the passage of time for a muon traveling at high speeds and changing velocities is observed to be slower when compared to a stationary observer. This effect is a result of Einstein's theory of relativity and has been confirmed through various experiments.
2. How does muon time dilation occur?
Muon time dilation occurs due to the relative motion between the muon and the observer. As the muon travels at high speeds, its time frame is stretched, causing it to experience time at a slower rate. This is because the muon's velocity adds to its time dilation, making time appear slower for the muon when compared to a stationary observer.
3. What is the significance of studying muon time dilation in accelerating frames?
Studying muon time dilation in accelerating frames is important as it helps us better understand the fundamental principles of time and space. It also has practical applications in fields such as particle physics and astrophysics, where high-speed particles and objects are involved.
4. Can muon time dilation be observed in everyday life?
Muon time dilation can only be observed in extreme conditions, such as high-speed particle collisions or in space. In everyday life, the effects of muon time dilation are too small to be noticeable. However, it is a crucial concept in understanding the behavior of particles and objects at high speeds.
5. Are there any other factors that can affect muon time dilation?
Yes, there are other factors that can affect muon time dilation, such as gravity. In the presence of a strong gravitational field, time dilation can occur due to the curvature of space-time. This is known as gravitational time dilation and is also a consequence of Einstein's theory of relativity.
