Musical instruments layout in an orchestra?
In summary, orchestras used to be placed in one section of the concert hall and the sound was mainly central in front of one.
SleepDeprived
31
I listen to rock music and usually in the musical mix, the drum is placed at the center/back of the soundstage, the vocal is at the center/front, and other instruments like guitar, piano are either are the left or right and slightly up front. So this gives a nice weight to the soundstage with the drum and vocal act as a foundation upon which others are built.
I notice that in an orchestra, the light instrument such as violin are placed on the left side, whereas the heavier instruments such as the cellos are on the right? Is that the usual convention? Are there any reasons for that? Whenever I listen to a classical piece, I also get this odd feeling like I am listening to the bass part on the right and the light part on the left as if I am listening to two separate events. Can the cellos be places at the center/back of the orchestra? Are there any reason why not?
Science news on Phys.org
There are many factors involved in the layout of the orchestra, and many varying opinions on the best layout. There is certainly no single ideal layout.
The first thing to note is that orchestral layout assumes that the listener will not be too close to the orchestra. The best seats are typically something like half way back in the concert hall. The sound should normally be primarily central in front of one, but it is sometimes helpful to have some stereo separation for passages where different parts play alternately, especially for higher pitched instruments (where human perception of direction is more accurate). Some devices and even recordings use "wide" stereo techniques where the difference between the left and right channels is artificially amplified, which doesn't often work well for orchestral music.
Some of the factors involved are as follows:
1. Section principals within a given instrument family (strings, woodwind, brass) should be as close together as practical, for best coordination.
2. Players of a given instrument part normally find it most practical to be grouped together (although some orchestras split double basses or even cellos between the two sides).
3. It is often easier for players and the conductor if instrumental parts with more closely related pitch are placed adjacent to one another, as it is common for two or more such parts to play closely related music. In particular, the first and second violins may sometimes be subdivided (into three, four or more individual lines) which may be easier to perform and better blended when the relevant players are tightly grouped. For example, one movement of Shostakovich Symphony No 5 is scored for 1st, 2nd and 3rd violins (of equal importance) playing in harmony, which typically requires some 1sts and some 2nds to play 3rd, so it is obviously more practical when the 1sts and 2nds are seated next to each other.
4. The sound from string instruments is somewhat directional, being stronger and more clear when facing the front of the instrument (with the holes in), although this effect decreases with lower pitch. In particular, cellos and double basses can sound stronger when placed towards the middle facing forwards, but second violins and violas sound a bit less strong when placed on the right facing the first violins. (On the other hand, the fact that second violins are facing the other way can help to provide a contrast in the sound for antiphonal sections).
5. Certain composers like to use antiphonal styles where two different parts alternately play similar music. In such cases, it may enhance the effect to have those parts well separated on the stage. However, different works may have different requirements.
Before the 20th Century, orchestras were typically small and the layout was often defined by the convenience of grouping around the keyboard/conductor. It was common to have the first and second violins on opposite sides for antiphonal effect, with cellos and basses somewhere in the middle facing forwards. J C Bach (youngest son of J S Bach) even wrote some works for double (string) orchestra, which are typically performed with a mirror image arrangement.
In the 20th Century, influential conductors Henry Wood and Leopold Stokowski decided to switch to what is now the common modern layout, with the strings going down in pitch from left to right, with the first and second violins together, then the violas, then the cellos on the right with the basses behind them. This is very practical for the players and conductor, but has this effect that one side is predominantly high pitches and the other is predominantly low pitches. Whether this is a good or bad thing generally depends on the work, but provided that one is not too close the effect generally blends well anyway. This blending may of course be undone by recording techniques which separate parts too much, simulating being too close to the orchestra.
Different orchestras may choose different layouts (often selected by the conductor), and this may also vary depending on the musical period of the works involved, but the Henry Wood arrangement is the most common at present.
The Hallé orchestra (based in Manchester) is well known for trying out alternative arrangements. They currently usually use first and second violins facing each other, with cellos and basses either in the middle or split evenly between the sides. (One of the co-principal second violins is the daughter of the couple who make up the other two players of the string quartet in which my wife and I play).
From some Googling I have found an interesting paper which covers these aspects and many more:
Orchestral Seating in Modern Performance by J D Smith: http://www.jdsmusic.co.uk/Orchestral Seating - JDS 2009.pdf
Likes zoobyshoe
On the other hand,
it's enjoyable to be close enough to see the musicians' facial expressions while they're playing. One sees them concentrating very hard in some passages and relaxed floating along with the melody in others. I used to sit front row just right of center at Montreal OSM concerts. A nice lady cello player came to recognize me and would occasionally come over to edge of the stage and chat after a performance. I was thrilled.
It must be wonderful to participate in an orchestra.
old jim
jim hardy said:
On the other hand,
old jim
I agree it's good to see expressions and body language; the best seats are usually a balance between being able to see the detail and getting the overall sound right.
The playing is usually very enjoyable, although often quite scary and difficult.
The organizing of it is not so enjoyable.
Some of the things I and my wife handle are as follows: trying to get the regular conductors to select works which suit our resources in time to promote next season; selecting concert dates without clashing with other local events; booking and paying for concert and rehearsal venues; finding suitable soloists and trying to book them for fees which we can afford; creating publicity materials, concert programme booklets, season tickets and separate tickets for venues which don't have their own box office; maintaining the website including links to the online ticket site; trying to extract subscriptions from players; maintaining player lists, especially full members of the orchestral society; working with fixer to try to prevent extras requiring fees which would break our finances; hiring or buying the music (if we don't have it in our own library); arranging insurance; handling Performing Rights payments; handling players who are peeved for many reasons (such as things conductor said to them); providing advance estimates of costs for each event for committee approval and replacing them with actual figures afterwards; providing annual reports for the Charity Commission (including accounts, which are mostly handled by our treasurer); creating and putting up direction notices around the site when we perform in a school (with arrows from car park to hall and directions around hall area to refreshments, toilets, different parts of the seating); arranging for people to sell programme booklets (at all venues) and tickets (when we perform in schools or community halls) ... well, I just keep thinking or more things.
Like most of life's best things -- 1% inspiration, 99% perspiration ?
What's the name of your orchestra?
Maybe for the strings. I've seen Bud Herseth's face turn colors that should just not be present in nature.
This seems more common than I would like. I know why they do this, but I'd rather be listening to the music than listening to the stereo, if you know what I mean.
And now, the mandatory orchestra layout joke. What's the difference between a bull and an orchestra? The bull has his horns in front and his [censored] in the rear.
Likes OCR, jim hardy and Jonathan Scott
We run the Havant Orchestras: Havant Symphony Orchestra, which is purely amateur but includes a lot of music teachers and similar, and Havant Chamber Orchestra, which has a mixture of amateur and paid players. There's lots more info including a few audio clips on our website. We sometimes play in other orchestras in the area too, which is more fun in many ways as someone else has to do the organization.
Related to Musical instruments layout in an orchestra?
1. What is the typical layout of musical instruments in an orchestra?
The typical layout of musical instruments in an orchestra follows a hierarchical structure, with the string section at the front, followed by the woodwind section, then the brass section, and finally the percussion section at the back. This allows for better acoustic balance and visual coordination among the musicians.
2. Why are the string instruments placed at the front of the orchestra?
The string instruments are placed at the front of the orchestra because they are the most numerous and provide the foundation of the musical composition. Placing them at the front allows for better projection of sound and coordination with the rest of the orchestra.
3. How are the woodwind instruments arranged in an orchestra?
The woodwind instruments are usually arranged in a semicircle, with the flutes on the left, followed by the oboes, clarinets, and bassoons. This arrangement allows for better communication and coordination among the different woodwind sections.
4. Why are the brass instruments usually placed behind the woodwinds in an orchestra?
The brass instruments are usually placed behind the woodwinds in an orchestra because they are louder and can project their sound over the other sections. Placing them at the back also allows for better balance and coordination with the rest of the orchestra.
5. How are the percussion instruments positioned in an orchestra?
The percussion instruments are usually placed at the back of the orchestra, behind the brass section. They are arranged in a way that allows for easy access to all the different instruments and ensures that their sound does not overpower the rest of the orchestra.
  • Art, Music, History, and Linguistics
  • Computing and Technology
11K
  • New Member Introductions
