Mutiple choice about hydroelectric power plant
In summary, the flow rate of water through a hydroelectric power plant's turbine can be increased by widening the inlet, which is done in response to an increase in demand for electricity (option B). The control gates are responsible for managing the water level in the reservoir and ensuring a steady flow of water through the turbine, regardless of how the excess water in the reservoir (option A) came about. The pressure in the reservoir is not a significant factor in determining the flow rate through the turbine.
Clara Chung
304
A hydroelectric power plant is built next to a reservoir with a water turbine beneath a dam. In normal operation, which of the following conditions will increase the flow rate of water, in kg s^-1 ,through the turbine.
(1) There are too much water in the reservoir.
(2) After a heavy rainfall
(3) There is an increase in the demand of electricity
A. (1) only
B. (3) only
C. (1) and (2) only
D. (2) and (3) only
The answer is B.
flow rate = p A v
Power output max = p A v g h
where p is the density of water, A is the cross sectional area of the turbine, v is the speed of water.
I know that (1) is incorrect because the gates will be opened to release the excessive water.
(3) is correct because the inlet to the turbine will be widened. flow rate = p A v, p and A are unchanged, so the velocity of water increases to increase the flow rate.
However how should I explain (2), from my intuition the pressure difference increases because there is a higher water pressure due to pgh , speed of the water should increases which results in a larger flow rate, why is the flow rate unchanged?
How does (1) occur if not as a result of (2)? Wouldn't the control gates operate to handle both situations in the same manner?
You need to think about (1) in terms of it being a given situation: there is too much water in the reservoir regardless of how it came about (perhaps the gates didn't operate or couldn't handle the necessary volume). So what other mechanism is in place to manage the flow rate through the turbine? You mentioned it in your analysis of (3).
Likes Clara Chung
Do you mean we don't have to consider the pressure in the reservoir because the width of the inlet will change to produce a steady electricity?
That's the idea, yes. The control gates are there to keep the water level within an acceptable operating range, while the turbine inlet can directly set a desired rate of flow through the turbine (so long as the water level is within the acceptable operating range).
Likes Clara Chung
Related to Mutiple choice about hydroelectric power plant
1. What is a hydroelectric power plant?
A hydroelectric power plant is a type of power plant that generates electricity using the energy of moving water. It typically consists of a dam, a reservoir, and a turbine that converts the kinetic energy of the water into electrical energy.
2. How does a hydroelectric power plant work?
In a hydroelectric power plant, water is stored in a reservoir behind a dam. When the water is released, it flows through a turbine, which spins and drives a generator to produce electricity. The water then flows back into a river or stream.
3. What are the advantages of hydroelectric power plants?
Hydroelectric power plants have several advantages, including being a renewable energy source, producing no carbon emissions, and having a long lifespan. They also provide flood control, irrigation, and recreational opportunities.
4. What are the limitations of hydroelectric power plants?
One limitation of hydroelectric power plants is their reliance on a constant source of water. This means they are not suitable for areas with low water levels or droughts. Additionally, the construction of dams can have negative impacts on the environment and local communities.
5. How common are hydroelectric power plants?
Hydroelectric power plants are the most widely used form of renewable energy, accounting for over 16% of the world's electricity production. They are particularly common in countries with large rivers and mountainous terrain, such as China, Brazil, and the United States.
  • Mechanical Engineering
