Mutual inductance of a coil inside a solenoid
The discussion focuses on the derivation of the mutual inductance formula for a coil inside a solenoid. It addresses the confusion regarding the treatment of the magnetic field B, which varies with time due to alternating current I1. Participants clarify that while B does vary with time, it can be considered uniform over the surface A2 at any specific instant, allowing it to be taken out of the integral. The key takeaway is that the flux is calculated as a spatial integral of B over A2 at a given moment. This understanding resolves the initial concerns about the derivation process.
Amaelle
Good day , i have an issue with the derivation of the mutual inductance of coil inside solenoid formula
I1 is an alternating current which means that B is varying, and we know that the Flux 21 is equal to the integral of the dot product of B and A2 but as B is varying we CAN NOT take it out of the integral and use the form used in the pic (the formula encercled in red).
Maybe there is something missing in my logic and any help would be highly appreciated, thanks!
You can take B out of the integral as long as B doesn’t vary with position.
thank you for your prompt answer, but I still have difficulty to grasp this point, isn t B varying with time?? because the current is alternating? thanks!
Yes, B varies with time. So the flux varies with time. But the flux at any particular instant of time is a spatial integral of B over the surface A2. At any particular time, B is uniform over the A2.
Likes Amaelle
Thanks a million ! you nail it !
  • · Replies 16 ·
