Mutual positions with varying paramenter
  • Thread starter Kernul
In summary, the two matrices produce different results depending on the rank of the first matrix. The directional vectors method does not work because the rank of the first matrix is not correct.
Kernul
211
In the Euclidean space ##E^3## we have the following lines:
##r : \begin{cases}
10bx + 4y - (b + 2) = 0 \\
bx + z = 0
\end{cases}##
##s : \begin{cases}
4y - 10z + 1 = 0 \\
x + 3y - 7z + 1= 0
\end{cases}##
Find the mutual position at the varying parameter ##b##.
I tried both methods, with the matrix and the directional vectors and in both I find myself wrong I guess. (sorry for the long post but I really want to understand this)
Matrix method:
I have two matrices. One made of the full equations:
##(A|d) = \begin{pmatrix}
10b & 4 & 0 & -b - 2 \\
b & 0 & 1 & 0 \\
0 & 4 & -10 & 1 \\
1 & 3 & -7 & 1
\end{pmatrix}##
and the other one made of the same full equations minus the last column:
##A = \begin{pmatrix}
10b & 4 & 0 \\
b & 0 & 1 \\
0 & 4 & -10 \\
1 & 3 & -7
\end{pmatrix}##
Now:
If the rank of the first is ##4## and the second is ##3##, then the two lines are askew.
If the rank of the first is ##3## and the second is ##3##, then the two lines intersect in one point.
If the rank of the first is ##3## and the second is ##2##, then the two lines are parallel.
If the rank of the first is ##2## and the second is ##2##, then the two lines are equivalent.
To know the rank of ##A## I'll take one of the squared submatrix of it and check the determinant. If the determinant is ##0## then I'll take another squared submatrix with one less row and one lest column.
Taking the following submatrix
##A' = \begin{vmatrix}
10b & 4 & 0 \\
b & 0 & 1 \\
0 & 4 & -10
\end{vmatrix}##
I have a determinant equal to ##0##, no matter what ##b## is. So I go deeper and check this other sub matrix:
10b & 4
b & 0
\end{vmatrix}##
Which has a determinant equal to ##-4b##. It is different from ##0## only if ##b## is different from ##0##. So, we have that the rank of it is ##2## for ##b \neq 0##. This means that the other matrix must be either ##3## or ##2##.
I'm going to write all the passages for the first matrix:
##(A|d) = \begin{vmatrix}
b & 0 & 1 & 0 \\
0 & 4 & -10 & 1 \\
1 & 3 & -7 & 1
\end{vmatrix} =
-b\begin{vmatrix}
4 & 0 & -b - 2 \\
4 & -10 & 1 \\
3 & -7 & 1
\end{vmatrix} -
\begin{vmatrix}
10b & 4 & -b - 2 \\
0 & 4 & 1 \\
1 & 3 & 1
\end{vmatrix} =
-b [-10(4 + 3b + 6) + 7(4 + 4b + 8)] - [4(10b + b + 2) - (30b - 4)] =
-b [-100 - 30b + 84 + 28b] - [48b + 8 - 30b + 4] =
-16b - 2b^2 + 18b + 12 = -2b^2 - 34b + 12##
The thing is that this should be ##0##, right? Why isn't it? What did I do wrong?
Directional vectors method:
I brought the two lines into parametric form, having then:
##r : \begin{cases}
x = -\frac{t}{b} \\
y = 10t + b + 2 \\
z = t
\end{cases}##
##s : \begin{cases}
x = -\frac{1}{2}t + 2 \\
y = \frac{5}{2} - 1 \\
z = t
\end{cases}##
So I have ##P_r (0, b + 2, 0), \vec v_r = (-\frac{1}{b}, 10, 1), P_s (2, -1, 0), \vec v_s = (-\frac{1}{2}, \frac{5}{2}, 1)##
Putting all these in the following matrix and finding the determinant:
##\begin{vmatrix}
0 - 2 & b + 2 - (-1) & 0 - 0 \\
-\frac{1}{b} & 10 & 1 \\
-\frac{1}{2} & \frac{5}{2} & 1
\end{vmatrix} =
\begin{vmatrix}
- 2 & b + 3 & 0 \\
\end{vmatrix} = +5 - \frac{b}{2} - \frac{3}{2} - 20 + 1 + \frac{3}{b} = -\frac{31}{2} - \frac{b}{2} + \frac{3}{b} = -\frac{31 + b}{2} + \frac{3}{b}##
Again, I find myself with something that should actually be ##0## independently of ##b##.
What am I doing wrong?
Concerning the matrix: you ignored the last row in the determination of the rank, that does not work.
I don't understand the steps that follow there, but the result is not the right determinant.
Likes Kernul
It's not that I ignored it, it's that since I already found a determinant that is already ##0##, it's useless to calculate another squared submatrix containing the other missing row. So I directly went for the smaller submatrix of 2x2.
I took the second row and did the cofactors with ##b## and ##1## (only these two since the other two numbers on the row are ##0##). Since they aren't on even positions, they are taken negative, so ##-b## and ##-1##. Same thing when the these two are multiplied to the other two determinants of the two matrices.
EDIT: I just noticed a mistake in the signs. My bad. It's like on WolframAlpha.
##r : \begin{cases}
bx + z = 0
\end{cases}##
##s : \begin{cases}
4y - 10z + 1 = 0 \\
x + 3y - 7z + 1= 0
\end{cases}##
I don't understand the question. What is meant by "mutual position"?
Meaning if they the two lines are parallel, intersecting or askew.
That only works if you start with square matrices and test possible all smaller matrices until you find one that has non-zero determinant, or until you tested all.
So I have to test all the small square matrices of ##A## and find a non-zero determinant? Only if I don't find any I will try with the smaller ones?
If you find a 3x3 matrix in A with a non-zero determinant then A has rank 3. If all 3x3 matrices in A do not have rank 3 then A cannot have rank 3 and you have to dig deeper.
It is usually easier to perform row/column operations that do not change the rank until the rank becomes obvious.
Likes Kernul
Oh okay, thank you.
The thing is that it feel easier for me to do it with the determinants than try randomly with row/column operations.
P. S. Sorry for the late reply.
It is not random, it would be like the Gauss algorithm.
Related to Mutual positions with varying paramenter
1. What are mutual positions with varying parameters?
Mutual positions with varying parameters refer to the relative positions of two or more objects in a system, where the parameters (such as distance, speed, or direction) between the objects are constantly changing.
2. Why is it important to study mutual positions with varying parameters?
Studying mutual positions with varying parameters allows us to better understand how objects interact in dynamic systems. This can help us make predictions and calculations for future events, as well as improve our understanding of natural phenomena.
3. What are some examples of mutual positions with varying parameters?
Some examples include the orbit of planets around the sun, the motion of waves in the ocean, and the positions of vehicles in traffic. These systems all involve multiple objects whose positions are constantly changing in relation to each other.
4. How do scientists study mutual positions with varying parameters?
Scientists use mathematical models and simulations to study mutual positions with varying parameters. These models can help us make predictions and understand the behavior of objects in dynamic systems.
5. What are some potential applications of understanding mutual positions with varying parameters?
Understanding mutual positions with varying parameters has many practical applications, such as predicting the paths of satellites in orbit, designing efficient transportation routes, and studying the behavior of weather patterns. It can also help us develop new technologies and improve our understanding of the natural world.
