My Confusion Regarding the Strong Force
In summary: That makes SO much sense! Thank you so much for clearing that up for me.In summary, the Strong Force acting between quarks (and the gluons themselves) in a single nucleon, ALSO acts between the quarks (and gluons) of neighboring nucleons a well.
Stan Stuchinski
In an effort to clarify my question, allow me first of all to state what I believe I DO understand:
All observed elementary particles are either fermions or bosons. Ignoring the Higgs boson (which gives other particles mass via the Higgs mechanism), there are four forces operating in the universe:
Photons are the force carriers of the electromagnetic field.
W and Z bosons are the force carriers which mediate the weak force.
(Hypothetical) gravitons are postulated to mediate gravity.
Finally, gluons are the fundamental force carriers underlying the strong force.
However, I am given to understand that the strong interaction is observable in two areas, and therein lies my confusion:
WITHIN a nucleon (a proton or neutron), the strong force acts between quarks, and is mediated by gluons. Unlike all other forces, this manifestation of the strong force does not diminish in strength with increasing distance. After a limiting distance (less than about 0.8 femtometer, the radius of a nucleon) has been reached, it remains at a strength of about 10,000 Newtons, no matter how much farther the distance between the quarks (resulting in quark confinement). THIS expression of the strong force is referred to as, simply, the Strong Force.
HOWEVER---
OUTSIDE a nucleon (a proton or neutron), the strong force acts between nucleons, and is mediated by pions. And… just like all other forces, this manifestation of the strong force does diminish in strength with increasing distance. After a limiting distance (about 1 to 3 femtometers) it becomes ineffective, and is overpowered by the electromagnetic force. THIS expression of the strong force is referred to as the Nuclear Force or Residual Nuclear Force.
THUS, IF I UNDERSTAND CORRECTLY---
The Strong Force acts WITHIN a nucleon (binding quarks together), is mediated by bosons called gluons, and does NOT diminish with distance, while the Nuclear Force acts OUTSIDE a nucleon (binding nucleons together), is mediated by bosons called pions, and DOES diminish with distance!
Can you see my confusion?
These two forces act on two different particles (quarks versus nucleons), are mediated by two different bosons (gluons versus pions), and have two different “spheres of influence” (0.8 fm versus 1-3 fm).
Can it be explained so my humble intellect can understand why two such seemingly disparate forces are both classified under the Strong Force, and why would not the so-called Nuclear Force be a FIFTH universal force?
Thanks in advance, fellow members, for your time and consideration,
Stan
While nucleons have no net color charge, they still consist of charged objects. Fundamentally, both effects follow the same rules - gluons interact with quarks and other gluons. The description of the interaction with pions is an effective description - it simplifies the interaction enough to make reasonable predictions.
Do you know the van der Waals force? It is a related concept in electromagnetism: an attractive force between uncharged objects with internal charges.
Thanks for your prompt response to my query, mfb; it is much appreciated.
I had to reread your answer a number of times, and then review the article on the van der Waals Force, but I believe I understand. Essentially, then, the Strong Force acting between quarks (and the gluons themselves) in a single nucleon, ALSO acts between the quarks (and gluons) of neighboring nucleons a well, overcoming the electrostatic repulsion.
Thanks again, my friend, and have a great day!
Stan
Likes mfb
Right.
The strong Strong force energy does not increase forever by distance... It will start increasing until sometime at a threshold, it will be favored (energetically) to hadronize [make a pair of quark antiquark]... then you are getting at these "large distances"/"lower energies" the effective mediation of pions instead...
In this context thinking of quarks bound with "strings" (of energy flux) is giving a better image of what is happening...
Ahhhhhh. Now THAT explains it perfectly. The key point that I couldn't get straight in my head was what the gluons WITHIN the nucleon (which bind the quarks inside the proton or neutron) had to do with the pions (quark/antiquark particles) OUTSIDE of the nucleon. I just couldn't grasp where the pions were coming from.
"Hadronization" is the key, and I appreciate your input.
Stan
It's an idea useful to remind you that. However I am not sure if that's the correct idea... In general a gluon itself would hadronize at large distances... It's a simplified view, and so I am not sure if it gives a complete answer... it's however getting a thumb up by me, because it's easily memorable ...
I think the correct way to put it, is that the strong interactions that are mediated by the gluons, have infrared divergencies, and so the QCD at that point is not perturbatively treatable . In other words there is no a-priori way to speak for gluons/quarks below a scale (QCD-scale) where your initial theory stops working /is ill-defined, since that region is already out of your theory . In that case the quarks form condensates and break the symmetry spontaneously, raising up the Nambu Goldstone Bosons which are the pions in that point. The experimental verification for example of the SU(2) isospin with the pion-triplet and nucleon-doublet is showing this is the case. Advances in Lattice QCD show that an effective field theory mediated by mesons (pions) are the best way to treat strong interactions at low energies/large distance... So your Effective Field Theory of QCD is replaced by the Effective Field Theory for the mesons.
PS. After some notification , from the above you can at least "get out of it" that QCD (quarks+gluons) don't work in all energy scales, and below some scale, it is replaced by another effective field theory.
FAQ: My Confusion Regarding the Strong Force
What is the strong force?
The strong force is one of the four fundamental forces of nature, along with gravity, electromagnetism, and the weak force. It is responsible for holding together the nucleus of an atom by binding protons and neutrons together. It is the strongest force in the universe, but it only operates at very short distances.
How does the strong force work?
The strong force is mediated by particles called gluons. These particles are constantly exchanged between quarks, which are the fundamental building blocks of protons and neutrons, to keep them bound together. The strong force is also responsible for the creation of new particles in high-energy collisions.
Why is the strong force important?
The strong force is essential for the stability of matter. If it were not for the strong force, protons and neutrons would not be able to stay together in the nucleus, and atoms would not exist. The strong force also plays a crucial role in nuclear reactions, such as fusion, which powers the sun and other stars.
How is the strong force different from the other fundamental forces?
The strong force is different from the other fundamental forces in several ways. It is the strongest force, but it also has the shortest range, only operating at distances smaller than the size of an atomic nucleus. The strong force is also unique in that it only affects particles with a property called color charge, which is not related to the colors we see in everyday life.
What are some current theories about the strong force?
Scientists are continually studying and developing theories about the strong force. One current theory is called quantum chromodynamics (QCD), which describes how the strong force works at a fundamental level. Another theory is string theory, which suggests that the strong force, along with the other fundamental forces, can be explained by tiny strings vibrating at different frequencies.
