My Dehumidifier Hygrometer Differs From Handheld by 10% on RH....OK?
  • Thread starter Thread starter kyphysics
    Dehumidifier
The discussion revolves around the significant discrepancy in relative humidity readings between a dehumidifier (49%) and a handheld hygrometer (39%), raising questions about their accuracy. Participants suggest that both devices could be within a margin of error, but emphasize that cheap hygrometers often lack precision. Age and calibration of the devices are noted as factors that can affect readings, with some suggesting that a third hygrometer could help average the results. The conversation also touches on the importance of understanding how humidity and temperature interact, particularly concerning mold growth thresholds. Ultimately, the accuracy of hygrometers varies widely, and users are encouraged to consider devices with published accuracy ratings for reliable measurements.
kyphysics
The relative humidity readings are:
49% dehu
39% handheld
That's when they are placed side-by-side in the same area. Could both be roughly accurate with a small margin of error or could one (or both) just be wildly off?
49% dehu
39% handheld
Yes. All of those are possibilities. How would you expect us to know?
Psychic abilities. :smile: Maybe I should have specified that I'm just curious too how people would handle this?
Buy a third hygrometer? lol Just average them? ...etc.?
  • Haha
Likes DaveE
Relative humidity measurements at the level of a common, cheap device is more about magic than accuracy.
You should consider those readings equally as 'comfortable'. That'll just fit the accuracy of such devices.
If you prefer to push this to the extreme then as a calibration, you can check the level of comfort according to the readings.
BTW thermometers are the same (to some extent). So just keep in mind that if you wish to know the temperature, then you should never buy a second thermometer, since that'll only bring confusion :wink:
What is the make/model of the handheld? It might have a published accuracy and I'd expect it to be much better than the one on the humidifier.
Ideally, a RH measuring device should 'equilibrate' quickly - In my experience that isn't always the case. Running the measuring devices side-by-side for an extended length of time might produce a smaller error.
Age matters too; humidity meter accuracy drifts/decays over time. I'm not clear on the operating principle, but whatever it is, it is a lot less stable/repeatable than, say, a temperature measurement.
Likes kyphysics
Stretching hair (human or animal, occasionally spider silk), or assorted artificial fibers in torsion mechanisms, or other mechanical linkages, ...
Likes Keith_McClary
Even in a digital meter?
Maybe for the cheap ones. Good sensors use engineered materials and look for changes in physical parameters like dielectric constant or resistivity. Trust me, you won't find farm animals in the production processes of modern sensor manufacturers.
https://www.fierceelectronics.com/components/choosing-a-humidity-sensor-a-review-three-technologies
https://www.sciencedirect.com/topics/materials-science/humidity-sensor
Likes russ_watters
https://www.amazon.com/gp/product/B06XTPTG1J/?tag=pfamazon01-20
~$15 Probably one of the cheaper ones, Russ. Not that price determines quality always, but just saying.
re: accuracy relative to price
How would one know the price threshold for accuracy? ...w/o buying the biggest/baddest hygrometer out there (w/ the assumption it's the most accurate)? It's a device I find useful, but wouldn't spend $100 on, for example...$50...mehhhh...okay, I'd spend that.
re: thermometer accuracy
Any data on the margin of error we're talking about for your average thermometer?
Btw, I am mainly interested in RH levels for mold growth thresholds (making sure my environment is below those levels). Usually not a big deal to me otherwise.
I have two electronic-based hygrometers in the same room about 7 feet apart, they are both an 'added feature' to battery operated clocks. One reads 38%, the other 58%.
A hygrometer in the dehumidifier reads 40%, which experience shows reads low relative to a wet-bulb/dry-bulb hygrometer. (currently out of service because of a mold-contaminated wick :cry:)
Based on the above numbers, I would consider random electronic hygrometers to have accuracy of ±10% of full scale.
Cheers,
Tom
Likes kyphysics, Rive and russ_watters
Also since they measure relative humidity, if you are holding your handheld in hot hands it may affect the reading.
Likes kyphysics
I don't know: never bothered with devices above $30...
By my experience, for these common/cheap things 2-3 degree (within the usual 0-50 degree Celsius) is pretty common.
That's a nasty topic, and contrary to the intuitive approach temperature is more important than raw RH value.
We have a wood stove (masonry heater, actually), and at winter RH can go as low as 25-30% (despite any effort to raise it a bit to the not-so-itchy range). And we still has some mold in the corners - mostly, because the comfortable temperature is way too high (around 23 degree Celsius) in this under-insulated house.
Check the RH vs. dew point graphs! Those are the most useful data for mold prevention.
The only way to really know an instrument's accuracy (when new) is to buy something with a published accuracy. For example, here's one with +/-5% accuracy for $27 USD:
http://www.extech.com/products/RHM15
You can find +/-2%, but they are typically much more expensive.
Temperature is much easier to measure. Typically you can find +/- 1-2F (or 1C) accuracy even in pretty inexpensive meters.
Likes kyphysics
  • · Replies 24 ·
  • · Replies 21 ·
  • · Replies 19 ·
  • · Replies 18 ·
  • · Replies 96 ·
11K
