My dilema in proving a theory (bending a steel tube)
In summary, the shaft must have a flexibility and durability that is equal in all directions in order to meet the requirements set forth above. However, if there is a variable gravity force then it might not be able to maintain the same orientation.
not_an_engineer
Hey everyone !
I am trying to learn how to mathematically prove that a steel tube (with wall thickness of ~ 1mm and external diameter of ~ 15 mm) will have ...
At any point along its length, the shaft must :
1) bend in such a way that the deflection is the same regardless of how the shaft is rotated about its longitudinal axis; and
2) twist the same amount in both directions
To make this even more difficult, I propose to bend channels into the shaft with 120 degree spacing, a depth of 2 mm and a width of 2mm (channels to be placed at 60 degrees, 180 degrees, and 300 degrees.) with a length, along the longitudinal axis, of 250 mm.
My issue is that I want to be able to mathematically prove that the combined resultant forces on the shaft will effectively remain constant, regardless of shaft rotation, due to the spacing of the channels. There is no requirement that I have found that states that all points along the tube must react in the same manner to other points along its shaft, in respect to flexing, bending or twisting
My hypothesis is that since the channels are spaced at 120 degree increments, the combined resultant forces when measured in any direction will be the same relative to the channel locations, but regardless of tube rotation, and can meet the requirements set forth above. I believe that if I can establish this theory mathematically, it will prove true in physical testing as well.
Any help that can be offered is greatly appreciated.
Can you tell us what is the use of this shaft and why you need to add channels?
What specifically are the resultant forces (torque vs. lateral vs combined) and where and how will they be applied to the shaft?
This may sound a bit overprotective, but I am not comfortable discussing the designed use for the shaft or the need to add the channels at this point. They are not dangerous in any way, but I still don't feel comfortable discussing that at this point. I hope this does not offend you or anyone else reading this thread. Thanks
No problem, just curious.
I can honestly say that I am not quite sure. As close as I can determine, I would need to be able to show through mathematical and physical testing that the characteristics of the shaft, i.e. flexing, bending and twisting, would be the same in any direction at any point along the length of the shaft, regardless of shaft orientation along the longitudinal axis. There is no evidence that I would have to prove the same characteristics between the channeled section and any unchanneled section.
I hope this didn't cause everyone to get even more confused.
Thank you for your inquiry
I hope I didn't offend.
Nope. :biggrin:
No offence taken.
Let me approach the issue from these perspectives.
1. As long as the applied forces remain in the same orientation to the centerline of the shaft there should be no reason to expect a change within what could described as a "uniform system" orientation shift. Additionally, the orientation change must also not introduce any dynamic forces if it occurs during the operational conditions of the shaft, i.e no gyroscopic or inertia effects form reorienting the rotating shaft.
2. However, if there is a gravity force component related to the shaft or any of the applied forces that will be variable due to a vertical angle orientation change in the shaft centerline or an applied force then that could present an problem even in the "uniform system".
Edited to add "inertia"
FAQ: My dilema in proving a theory (bending a steel tube)
How do you plan to prove your theory about bending a steel tube?
To prove my theory, I will conduct a series of experiments and gather data to support my hypothesis. I will also consult with other experts in the field and review existing literature on the topic.
What challenges do you anticipate facing in proving your theory?
I anticipate facing challenges such as obtaining accurate measurements, controlling variables, and ensuring the reliability of my results. Additionally, there may be limitations in the materials and equipment available for my experiments.
How will you ensure the validity of your results?
To ensure the validity of my results, I will use a scientific method and follow strict protocols in my experiments. I will also conduct multiple trials and analyze the data using statistical methods to minimize errors and increase the reliability of my findings.
What potential applications can your theory have in the real world?
If my theory is proven, it could have various applications in industries such as construction, engineering, and manufacturing. It could also potentially lead to the development of new techniques and technologies for bending steel tubes.
How will you communicate your findings to others?
I plan to publish my findings in reputable scientific journals and present my results at conferences and seminars. I will also share my research with other scientists and professionals in the field through collaboration and networking.
11K
