jeff m
- 1
My kids have some question to ask so bear in mind that they are in grade school.
Hi,
We have been talking and learning about motion and studying examples to understand concepts. One discussion was about what happens when you take a fan and blow it into another fan. The first fan would cause the second fan to spin and it could create power from the second fan if it were set up to do so, but not enough power to run the fist fan. I understand this.
This got me to "daydream", which brought me to my questions. This is mostly about the concept so the exact details are less important.
You have a fan that required X amount of electricity to run it at a constant rpm which produces a wind velocity of 25 miles per hour. This fan is on a table in your back yard on a calm day.
Next, you have a "tunnel" (or pipe or tube slightly bigger than fan in above example). Through this tunnel is blowing a constant natural wind of 25 miles per hour. You place a similar fan (as the above example) inside this "tunnel" and turn it on. Given the fact that the tunnels natural wind speed is 25 mph and your fan will create a wind speed of 25 mph, I want to know what changes there might be to the required power used to operate the fan. Would the fan in the "tunnel" be using less electricity once it is at its operating speed? If not could changes be made to the fan such as using a much lower power consumption motor to run it. I wonder if it would be possible to remove the regular motor and put on a motor that would NOT be able to do the "work" required to get the fan started and up to the 25 mph speed (such as on the table in the backyard), but this "weaker" motor would be able to maintain the rpms at the 25 mph after "using" the tunnel wind to get it "up to speed".
You may think, "well, if the natural wind is 25 mph and you want to run the fan at 25 mph you could just disengage the fan motor and the natural wind would accomplish what you want at zero energy cost. This is beside the point of my question. All I want to know it the difference between the energy use in the first example and the second example, without the wind and with the wind.
But, to advance the conversation to make more sense, what if you wanted the fan to push the power 1 mph past the natural wind speed, from the 25 mph to 26 mph? Would this mean that now the 25 mph natural wind does nothing to help reduce the energy/electricity needed to operate the fan at 26 mph?
Thank you for your thoughts.
J
Hi,
J
