My temperature after dropping ice in tea isn't adding up
In summary: C)?Yes, as Collinsmark is saying, the left hand side of the equation is supposed to be the amount of heat lost by the water to the ice, not the amount of heat gained by the water.
Eclair_de_XII
1,083
91
"If a cup of tea (175.0 mL, 90.0°C) is cooled by adding an ice cube (25.0 g, -15.0°C), what is the final temperature of the tea? The heat required to melt ice (heat of fusion) is 80.0 cal/g."
S.H. of water (solid) = 0.5 cal/g°C
1 cal/1 g°C ⋅ 175.0 g ⋅ (x - 90.0°C) = 0.5 cal/1 g°C ⋅ 25.0 g ⋅ 15.0°C + 80 cal/1 g ⋅ 25.0 g
175x - 15750 = 187.5 + 2000.0
175x = 17937.5
x = 102.5°C
This is not adding up. The final temperature should be lower than 90.0°C, not higher.
175x = 17937.5
x = 102.5°C
[Changed some text color.]
Right. If x is less than 90.0o it would make the term in red negative, meaning that the whole left hand side of the equation would be negative. Are you sure you want to set the problem up that way?
The water in the ice cube starts off at -15°, but what is its final temperature here?
Also, you need an additional term on the right hand side of the equation somewhere. Once the ice finishes melting, that corresponding water, that was once ice, must rise to temperature x. That needs to be represented in there somewhere. [Edit: NascentOxygen beat me to it. :woot:]
Yes, as Collinsmark is saying, the left hand side of the equation is supposed to be the amount of heat lost by the water to the ice, not the amount of heat gained by the water. Also, on the right hand side of the equation, you are missing a term representing the heat required to raise the temperature of the water from the melted ice to the final temperature.
EDIT: Oops. Double scooped.
Chet
175x = 17937.5
x = 102.5°C
I think you need to equate the total heat at the start (tea-cube-latent heat) to that at the end when melting stops.
I think your equation is slightly adrift. The total heat at the start is that of the hot tea, minus that of the cube getting up to melting point, minus the latent heat. The heat at the end is the new volume of tea x unknown temp. The heat before and after is equal, so you can make an equation.
I'm told by my textbook that I have to make everything on the right-hand side negative. In any case:
1 cal/1 g°C ⋅ 175.0 g ⋅ (x - 90.0°C) = -(0.5 cal/1 g°C ⋅ 25.0 g ⋅ (x + 15.0°C) + 80 cal/1 g ⋅ 25.0 g)
175x - 15750 = -12.5x - 187.5 - 2000
187.5x = 13562.5
x = 72.3333... °C
So it should be: "1 cal/1 g°C ⋅ 175.0 g ⋅ (x - 90.0°C) = -(0.5 cal/1 g°C ⋅ 25.0 g ⋅ (x + 15.0°C) + 80 cal/1 g ⋅ 25.0 g)"?
I was actually sure that was what I was describing with the left-hand side of the equation.
I'm honestly not sure what you mean.
What's the heat capacity of the liquid water that forms after the ice melts? Is it the same as the heat capacity of the ice? If not, then please reconsider this term: 0.5 cal/1 g°C ⋅ 25.0 g ⋅ (x + 15.0°C)
Chet
So: 1 cal/1 g°C ⋅ 25.0 g ⋅ (x - 15.0°C)?
No. (0.5)(25)(0 + 15) + (1)(25)(x - 0)
Chet
In post #6, tech99 is discussing a more advanced method of solving a problem like this. It is based on making use of the methodology that you learn in Thermodynamics: since the system is insulated and no work is done by the system, the change in "internal energy" of the system is zero. You will learn all about this when you study Thermo. For now, concentrate on the way that your professor is teaching it to you.
Chet
I'll keep that in mind.
1 cal/1 g°C ⋅ 175.0 g ⋅ (x - 90.0°C) = -(0.5 cal/1 g°C ⋅ 25.0 g ⋅ 15.0°C + 80 cal/1 g ⋅ 25.0 g + 1 cal/1 g°C ⋅ 25 g ⋅ x°C)
175x - 15750 = -187.5 - 2000 - 25x
200x = 13562.5
x = 67.8°C
200x = 13562.5
x = 67.8°C
I think that's right. :smile: Good job!
Personally, I would have kept the right hand side of the equation positive and on the left hand side of the equation substituted "x - 90.0o" with "90.0o - x" making both sides of the equation represent positive energies. But that's just me. Your approach works too.
Likes Chestermiller
Thanks again, guys.
Related to My temperature after dropping ice in tea isn't adding up
1. Why does my temperature decrease when I add ice to tea?
When ice is added to tea, the ice absorbs heat from the tea in order to melt and reach thermal equilibrium. This transfer of heat causes the temperature of the tea to decrease.
2. Is it normal for my temperature to decrease when I add ice to tea?
Yes, it is completely normal for the temperature of tea to decrease when ice is added. This is due to the heat transfer that occurs between the tea and the ice.
3. Why does the temperature seem to decrease more slowly when I add ice to hot tea compared to room temperature tea?
This is because the hot tea has a higher temperature compared to room temperature tea, so it takes longer for the ice to reach thermal equilibrium and melt. The rate of heat transfer is directly proportional to the temperature difference between the two substances.
4. How does the type of cup or glass affect the rate at which the temperature decreases?
The type of cup or glass can affect the rate at which the temperature decreases because it can impact the surface area of the liquid exposed to the ice, as well as the thickness of the cup or glass which can affect the rate of heat transfer.
5. Can I use this method to quickly cool down my tea for drinking?
Yes, adding ice to tea is a common method for quickly cooling down the temperature for drinking. However, it is important to note that adding ice can also dilute the flavor of the tea, so it is a personal preference whether or not to use this method.
