- #36
Fredrik
Staff Emeritus
- 423
OK, I'm going to have another look at it. (I haven't done it yet).Ich said:Yes, r == psi. I simply use A=1, which means dimensionless r and a scalefactor with units of time or length.
Proceed with the total derivative
[tex]dt' = \frac{\partial t'}{\partial t}dt + \frac{\partial t'}{\partial r} dr = cosh(r)dt + t\, sinh(r) dr[/tex]
and so on, insert in the metric, sort it out and find the minkowski metric.
Edit: I still haven't looked at it, but I realized that I forgot to mention why I would be very surprised if this works. If a change of variables can bring the metric to "Minkowski form", then the spacetime we're dealing with is Minkowski space. That spacetime is the solution with k=0, ρ=0, Λ=0, so I don't expect to find another copy of it among the k=-1 solutions.
I'm aware of this flaw in the visualization I described, but it's a minor flaw, and you could easily have corrected it rather than dismiss the whole thing. I thought about making a post earlier to say that time is represented by a function of the distance from the center instead, but I was too lazy. What that function is depends on the density and pressure.Ich said:Spatial geodesics generally have not much physical meaning. In this case, it's clear that the curved spatial geodesics can't be spacetime geodesics.
That's not a FRW universe, since you have constant [tex]\dot a[/tex]. I don't know if this visualization is helpful,
I think this way to visualize a FLRW solution (with positive curvature) is very useful. It has helped me to understand many weird things about cosmology in the past.
Edit: The "flaw" discussed above isn't really a flaw. It's a just convenient way to represent the positive-curvature solution. It should be adequate for most purposes. It's true that if a(t)=constant*t for all t, then it isn't a FLRW solution, but we really don't have to think of the radius of a sphere as a(t). The radius R can be a function of a(t): R(t)=r(a(t)), and if we choose the r to be the inverse of a, we'll have R(t)=t. Yes, I know that a isn't invertible, but the restriction of a to the open interval from the big bang to the moment where the expansion reverses is invertible, so we can at least represent the era during which the universe is expanding this way.
That's definitely incorrect. Inflation only explains why the distance is currently so large. The effect we're talking about (distant objects moving away from us at a speed that grows with distance) is present even in a FLRW solution without inflation.Ich said:The cause is inflation (in the standard model)
Yes, but that's not what you're doing. We're talking about a region of spacetime that we have selected specifically because it's so large that its curvature can't be neglected. I will make this point more clear below.Ich said:What we have now is an almost empty spacetime, where we can start with flat/Newtonian/postNewtonian approximations at each event, and try to look at it from this point of view.
I will look more closely at this claim. I'm not 100% sure that the visualization I suggested is adequate for this, but if it is, it implies that you're wrong about this.Ich said:No. Examine the empty universe example, where normal coordinates apply to all of spacetime. Neither is c!=1, nor are the time coordinates the same.
That doesn't answer my question. How do you know that the result of that procedure is that "events separated by a certain proper time on [the world line] are separated by a larger coordinate time."? Suppose that P and Q are two events on the world line of galaxy A, with P being "earlier" than Q. Suppose that we're considering the normal coordinate system associated with galaxy B's motion at an event R on its world line, where R has been chosen such that the time coordinate of P is =0 in this coordinate system. Do you know how to calculate the time coordinate of Q? I don't.Ich said:You have the metric, the worldline, and you can read off the time coordinates and integrate to get proper time.
I also expect the difference between the time coordinates of P and Q to depend on the choice of R (the origin of the normal coordinate system). What if we e.g. choose R such that the time coordinate of Q is =0 and calculate the time coordinate of P? Will the difference be the same? It would be in SR, but this isn't SR.
I don't know why you're saying "therefore" as if the conclusion is an immediate consequence of what you said before. It makes me think that you keep making the (big) mistake to think that SR results can be immediately transferred to GR. Galaxy B is at rest in the normal coordinates of galaxy B, and in FLRW coordinates. Galaxy A is at rest in FLRW coordinates, and in the normal coordinates of galaxy A, but not in the normal coordinates of galaxy B. The only conclusion you can make immediately (due to the equivalence principle) is that if an object X is stationary in the normal coordinates of galaxy B and its world line intersects the world line of galaxy A, then there's time dilation between the normal coordinate systems of object X and galaxy A. You can not immediately conclude anything about what the time dilation is between the normal coordinate systems of the galaxies. You would have to calculate it, and as I said before, the result may depend on which point on galaxy B's world line you take to be the origin of its normal coordinates.Ich said:Normal coordinates define a set of observers that are at rest wrt the origin. FRW comoving particles have relative velocity to these observers, therefore, at any point, there is time dilation wrt the respective "static" observer.
I think we should ignore the fact that spacetime geometry isn't really FLRW near a galaxy for now. We shouldn't introduce additional complications until we have solved the "simple" problem.Ich said:Those static observers are additionally up or down a gravitational well, therefore their clocks are generally ticking at a different rate than the one at the origin.
