Myocytes and neurones, initiating activity.
  • Thread starter nobahar
  • Tags
    Activity
In summary: That's an interesting question. Some neurons do initiate action potentials, its not solely from pre-existing ones. Sensory neurons are the best example---they initiate action potentials after being stimulated by numerous methods (pressure, temperature, strain, pH, etc). Additionally all neurons do experience some stochastic excitation, and occasionally an action potential will spring up.The first action potential in the CNS may be generated from sensations carried to the brain via the thalamus and reticular formation. Since the thalamus is usually the one maintaining the basal electrical rhythm, it may have been the one that initiated it when the CNS first starts functioning. The neuron may have an inherent property to start
nobahar
497
Hello!
Peculiar question. I was hoping that someone, probably with a background in development or neuroscience, could answer this question for me:
The contraction of heart muscles is achievable independently of any 'outside' source because the heart muscles can initiate action potentials themselves.
I could not find anything on any specialised neurons having a similar property, so how is the CNS 'kickstarted'? Action potentials arise in neurons by depolarisation induced by other neurons. So how is the first action potential in the newly developed/developing CNS achieved?
Does it require interaction with the outside environment?, which could generate action potentials that are relayed to the CNS, and from there the signal is simply 'maintained'?
I assume that the brain is always 'on' from the point forward of the first action potential.
As an analogy: If the cardiac myocytes were not able to initiate action potentials independently, it would require an outside source, it could then have some mechanism for maintaining a controlled contraction. This is not of course the case, since the heart is myogenic.; but since neurons do not appear to have this property to initiate action potentials independently, then there must be something to initiate the first action potential, action potentials could then be maintained within the CNS, I suppose.
Does the question make sense?
Admittedly it's a little peculiar!
Thanks in advance.
Biology news on Phys.org
Thanks for the response zhermes.
This is what I was wondering. Does it require outside stimulation for the nervous system to 'get started'? Without outside stimulation, would there be brain activity? Perhaps there would be basic functions like breathing, etc, but again how is this kick-started? Higher functions might rely on outside stimulation, I guess.
I wonder if this is sufficient to induce the brain into organised and regular activity. I do not know where to begin looking for this information, since it's difficult to articulate.
Perhaps the first AP is generated from sensations carried to the brain via the thalamus and reticular formation. Since the thalamus is usually the one maintaining the basal electrical rhythm, I suppose it was the one that initiates it when the CNS first starts functioning. The neuron may have an inherent property to start discharging as soon it is mature, even if only partially(graded potentials). These excitatory potentials then summate each other and generate an AP...kindly correct me if i am mistaken...:smile:
Hello there! I can provide some insight into this question for you. Myocytes, or heart muscle cells, are indeed unique in their ability to initiate action potentials without any outside source. This is due to the presence of specialized cells called pacemaker cells in the heart's sinoatrial node, which generate electrical impulses to stimulate the contraction of myocytes.
In contrast, neurons in the central nervous system (CNS) rely on other neurons to generate action potentials. This is because neurons are highly specialized cells that require specific signals to fire, and they do not have the same pacemaker cells as myocytes. So, how does the CNS "kickstart" and generate the first action potential?
The answer lies in the development of the CNS. During embryonic development, the nervous system goes through a process called neurogenesis, where stem cells differentiate into specialized cells, including neurons. These neurons then grow and form connections with other neurons, forming neural networks. This process is guided by genetic and environmental factors, and it is during this process that the first action potentials are generated.
In summary, the CNS does not require an outside source to generate action potentials, but rather relies on the development and formation of neural networks. Once these networks are established, the CNS can maintain its own activity without the need for external stimuli. I hope this helps clarify your question. Thank you for your curiosity and interest in science!
Related to Myocytes and neurones, initiating activity.
1. What are myocytes and neurones?
Myocytes and neurones are both types of specialized cells found in the nervous system. Myocytes are muscle cells responsible for contraction and movement, while neurones are nerve cells responsible for transmitting signals throughout the body.
2. How do myocytes and neurones initiate activity?
Myocytes and neurones initiate activity through electrical signals. In myocytes, these signals are generated by the movement of ions across the cell membrane, which triggers a chain reaction leading to muscle contraction. In neurones, these signals are generated by the movement of ions across the cell membrane and the release of neurotransmitters, which transmit signals to other neurones or to muscles.
3. What is the role of myocytes and neurones in the body?
Myocytes and neurones play crucial roles in the body's functioning. Myocytes are responsible for movement and support of the body, while neurones are responsible for transmitting signals that control bodily functions such as breathing, heart rate, and digestion. Both types of cells are essential for maintaining homeostasis and enabling us to interact with our environment.
4. How do myocytes and neurones communicate with each other?
Myocytes and neurones communicate with each other through the nervous system. Neurones transmit signals to other neurones or to myocytes through the release of neurotransmitters, which bind to receptors on the target cells and trigger a response. This communication allows for coordinated movement and bodily functions.
5. What happens when there is dysfunction in myocytes and neurones initiating activity?
If there is dysfunction in myocytes and neurones initiating activity, it can lead to various health issues. For example, dysfunction in myocytes can result in muscle weakness or paralysis, while dysfunction in neurones can lead to neurological disorders such as Alzheimer's or Parkinson's disease. It is important to maintain the health and proper functioning of these cells for overall well-being.
  • Biology and Medical
10K
19K
  • Quantum Interpretations and Foundations
