- #36
choran
- 51
Mentz, if so, did it contract to the point where my velocity relative to the pulse became zero in order to keep c invariant? Thanks.
Supposing I've understood the scenario correctly - there is no 'if', the distance is contracted.choran said:Mentz, if so, did it contract to the point where my velocity relative to the pulse became zero in order to keep c invariant? Thanks.
choran said:Well, still hard for me to internalize that one. Certain can see exactly what you are saying, it sounds good. Can't get over that at the exact moment A is measuring B's clock as slow, B at that exact moment is measuring A's clock as slow. It's not a matter of perspective--that would be easy to accept, as in the height analogy dvf gave above.
In the clock situation, we can't say "Freeze and let me back off and I'll tell you who's taller, as in the height analogy." Can't say "freeze, show your watches" and declare a winner. Not at all hard for me to see how in various real world scenarios A sees B's as slower. What is hard is the idea of symmetry, if that's the right word.
The concept (still talking SR only) that if A and B are moving relative to one another, A has just as much right to consider himself as stationary as B does, and vice versa, leading to what I just can't swallow. Rocket leaves earth--universe did not get up and move away from rocket. Earth did not pick up and go--the rocket left.
Muon example--Rocky Mountains did not rush up to meet the muon, no matter how much a conceited muon might
believe that. lol Rocky mountains did not become foreshortened, etc. Muon decayed at speed. Muon might measure my clock as slow, but the muon, I believe, would be wrong. Oh, well, back to the same old problem.
I think one has to go through physics boot camp, have a D.I. for several years, and then this stuff is internalized.
Otherwise, no shot. Thanks again, buddy.
As the space-time drawing shows, A and B are observing historical events at different times. If each sent a signal to the other at t1, it would return at t2. The red curves show each would measure the same round trip time, and observe the other clock at t = 1, i.e. symmetrical results.Can't get over that at the exact moment A is measuring B's clock as slow, B at that exact moment is measuring A's clock as slow.
choran said:That is a very clear explanation, I for some reason I have no problem with agreeing. When it is put that way, it seems (is?) quite uncontroversial and sensible. If I look at SR as simply being an issue of how to measure velocity given the relativity postulate and the light invariance postulate, I have very few issues. The idea that time is variable and observer dependent is what gets me. I still see these two things as different. I don't think there's anything that will ever get me to easily accept the notion that there is no absolute time. I know this probably makes no sense, but that's my difficulty. Maybe it's how SR is taught. I don't see time slowing, I see and can accept how its measure, if we use light, will vary.
Maybe it's also an issue of some of the basic examples, like the one we always see of the parallel mirrors on the train, where the light bounces straight up and down for the guy on the train, but traces a longer path (the hypotenuses of two triangles) for the ground-based observer. My reaction is simply to yell "Hey, what's the big deal, you are just measuring two different things, of course you will get different answers!"
choran said:Thank you all for the responses. May I ask if you all concur with the post of Mentz114 re: distance contraction?
Having a bit of trouble with that one. Thanks again.
choran said:Thanks, Nug: In my example, light went 1 LY. I traveled 1/2 LY behind it, in same direction. No return beam, no additional facts. Are you saying "You didn't really travel 1/2LY" or are you saying "The light pulse didn't really travel 1 LY" or ? How far did I go, and at what velocity?
Ok, here's the first diagram:choran said:Let me star with 1.
Yes, both the Proper Time for you, the black traveler, and the Coordinate Time are somewhat over 1 year when the reflection gets back to you.choran said:Is diagram 1 indicating that the light reflection from the star will reach me, the black line traveler, at somewhat over 1 year?
Yes, but only in the Inertial Reference Frame (IRF) depicted in diagram 1 which is the rest frame of the motionless guy and the star. Any time you discuss "when" something happened remotely, you must specify the IRF in which it applies. Here is your rest frame during the trip:choran said:If so, we have to stop right there. I would say that when the light reaches the star, I will have traveled exactly halfway to the star. Are we in agreement on that?
You're going to have to show me how that happens. Can you draw a diagram to depict this?choran said:Light will bounce, and reach me in less than one year total.
That's true in the Earth's rest frame but the two times are equal in your rest frame. But then it's the star that is moving, not you.choran said:The time from Earth to bounce is not the same as bounce to me, because I have moved toward he star.
OK, and we'll look at what happens in both of the above rest frames.choran said:But let's not even talk about the bounce. Let's just stop when the pulse reaches the star, OK?
You stated in post #21 that you have very little issues with either of Einstein's two postulates. The second one states that light travels at c in any IRF so that is your answer.choran said:Let me ask: How fast did the light travel?
It's wrong because you're combining statements about two different IRF's. You have to stick with one at a time. You can't use some parameters "relative to the guy on earth" and some parameters "relative to me" and do arithmetic on them and expect to come up with a valid conclusion. This is the source of virtually all of the so-called paradoxes in Special Relativity.choran said:Well, relative to the guy on Earth who stayed behind, it traveled at c, and took one year to go 1 LY. Relative to me, the light traveled a total of 1LY minus the distance of .5 light year I traveled during the same time. Net gain for light=1/2 LY. Why is it incorrect to say that relative to me, light traveled at 1/2c from Earth to the star?
