I N-body simulation of high or low-mass dark matter particles
N-body simulations reveal significant challenges in distinguishing the distribution and dynamics of dark matter based on particle mass due to current resolution limits, which are around 10^4 to 10^5 solar masses. This resolution is insufficient to accurately resolve the mass of dark matter particles, which are theorized to be much lighter. While computational limits exist, improvements are unlikely to bridge the vast gap between simulation particle masses and the expected mass of dark matter. Studies like Lovell (2020) and Yepes (2013) explore different dark matter models, including Warm and Cold Dark Matter, but the effectiveness of these simulations is constrained by their resolution. Overall, the ability to discern differences in dark matter behavior based on mass remains limited by current simulation capabilities.
Ranku
Do we notice any significant difference in distribution and dynamics of dark matter in galaxies when n-body simulations are done with high or low-mass dark matter particles?
Astronomy news on Phys.org
What do you mean by high or low mass? If you are thinking of resolving the mass of the DM particles this way, you need to know that the resolution of the simulations is nowhere near the level of being able to do this. I think the highest resolution n-body simulations have particle masses on the order of 10^4 to 10^5 Msun.
Likes Vanadium 50
I didn't know that the mass resolution is that low. Is it a computational limit, and therefore can improve?
Yes it is a computational limit. But 10^5 Msun is at least 50 orders of magnitude greater than a presumed DM particle, so don't hold you breath. Unless of course DM is primordial black holes...
Lovell (2020) employs the EAGLE simulation to compare Warm Dark Matter (i.e. keV scale particles), Cold Dark Matter (i.e. GeV scale particles) and Self-Interacting Dark Matter models. https://arxiv.org/abs/2002.11129v1
The CLUE simulation compares WDM and CDM models in Yepes (2013). https://arxiv.org/abs/1312.0105
A survey of WDM to CDM comparisons by multiple means can be found in de Vega (2011). https://arxiv.org/abs/1109.3187
Axion-like Dark Matter (i.e. ultralight) and Cold Dark Matter models are compared in Marsh (2015) although most not by simulation methods. https://arxiv.org/abs/1510.07633
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
