N elevators serving M floors most efficiently
  • Thread starter Thread starter Loren Booda
Loren Booda
What kind of algorithm aptly describes the solution to this problem?
Would you want to take into account that the bottom floor will be used most often therefore at least one elevator should idle there when not in use?
A good constraint for a variable minimum N vs a variable maximum M.
Oh right, I don't think I will be able to help with this question but I think that you will need another variable for how many people use the elevators.
Assume that the floors above ground are called at random.
Thread 'Determine whether ##125## is a unit in ##\mathbb{Z_471}##'
This is the question, I understand the concept, in ##\mathbb{Z_n}## an element is a is a unit if and only if gcd( a,n) =1. My understanding of backwards substitution, ... i have using Euclidean algorithm, ##471 = 3⋅121 + 108## ##121 = 1⋅108 + 13## ##108 =8⋅13+4## ##13=3⋅4+1## ##4=4⋅1+0## using back-substitution, ##1=13-3⋅4## ##=(121-1⋅108)-3(108-8⋅13)## ... ##= 121-(471-3⋅121)-3⋅471+9⋅121+24⋅121-24(471-3⋅121## ##=121-471+3⋅121-3⋅471+9⋅121+24⋅121-24⋅471+72⋅121##...
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
It is well known that a vector space always admits an algebraic (Hamel) basis. This is a theorem that follows from Zorn's lemma based on the Axiom of Choice (AC). Now consider any specific instance of vector space. Since the AC axiom may or may not be included in the underlying set theory, might there be examples of vector spaces in which an Hamel basis actually doesn't exist ?
