N-spheres as closed C^inf-manifold
  • Thread starter Philip2016
  • Tags
    Closed
In summary: This can be seen by considering the function ##g: S^n \to S^n## defined by:g(x_0,x_1,x_2,\ldots,x_n)=-x_0^2+x_1^2+x_2^2+\cdots+x_n^2If ##F## is a closed set, then for every point within ##F## there is a neighborhood within which the function ##g## is continuous, and the function ##f## is also continuous in this neighborhood.
Philip2016
I need to prove that the unit n-sphere is a closed C^inf-manifold, and am not sure what to do.
The unit n-sphere is defined as:
S^n = {(x_0,...,x_n) belongs to R^(n+1) | (x_0)^2+...+(x_n)^2=1}
It's not a proof, but a simple example of transfering any point x of distance r to origo on the spherical coordinate system to the unit n-sphere, through the infinetly differentiable function 1/r. But this is no proof, just an example. How do I prove that a certain manifold is 1) closed/opened (has/doesn't have boundary, i.e. delta M = the zero set), 2) topological/smooth/C^k?
Thanks in advance for any help.
To prove closure, I suggest you use the theorem that a set is closed iff it contains all its limit points. For given values ##x_1,...,x_{n-1}## find all limit points whose first ##n-1## coordinates are ##x_1,...,x_{n-1}##, and show that all such limit points are in ##S^n##.
To prove ##C^\infty##, you could choose an atlas in which the hypersphere is very nearly flat within each chart, which will be the case if each chart is very small. You should be able to define an atlas in which all points within each chart lie within distance ##\delta## of one another. Then you just need to prove that, on the region of overlap between any two overlapping charts (which will be a very small region), the transition map is infinitely differentiable.
An easier method is to use that a function ##f## is continuous iff for every closed set ##F## holds that ##f^{-1}(F)## is closed.
Related to N-spheres as closed C^inf-manifold
1. What is an N-sphere?
An N-sphere is a geometric object in n-dimensional space that is defined as the set of all points that are a certain distance from a center point. In simpler terms, it is a multidimensional version of a circle.
2. How is an N-sphere different from a regular sphere?
While a regular sphere exists in three-dimensional space and can be visualized as a round ball, an N-sphere exists in n-dimensional space and cannot be visualized in the same way. Additionally, an N-sphere has a radius that is defined by the number of dimensions it exists in, rather than a specific length.
3. What does it mean for an N-sphere to be a closed C^inf-manifold?
A closed C^inf-manifold refers to a topological space that is smooth and has no boundary. This means that an N-sphere is a continuous and differentiable surface that has no edges or boundaries.
4. What are some applications of N-spheres as closed C^inf-manifolds?
N-spheres as closed C^inf-manifolds have applications in various fields such as physics, computer science, and engineering. They are used in modeling physical phenomena, creating computer graphics, and solving optimization problems, among others.
5. How are N-spheres as closed C^inf-manifolds studied in mathematics?
The study of N-spheres as closed C^inf-manifolds falls under the branch of mathematics known as topology. Topology is concerned with the properties of geometric objects that remain unchanged under continuous deformations, and N-spheres as closed C^inf-manifolds are a key example of this type of object.
