Name of this electrical circuit?
In summary, the circuit is a voltage divider where the voltage across the load can be anywhere between 30 and 0 volts. It is commonly referred to as a Manually Controlled Variable Potential Reduction Demonstrator.
nivaOne
Hi,
I'm woundering whether this circuit has some kind of dedicated name in the field?
https://dl.dropboxusercontent.com/u/22589354/VoltageDivider2.jpg
It's not just the average voltage divider as it it influences the serial part as well the parallel part in the same time.
And does anybody know when it is typically used?
Thanks,
NivaOne
Rp is set up as a voltage divider driving RB as a load.
Looks like Rp is a potentiometer...like Simon said above, looks like a voltage divider, where the voltage across Rb can be anywhere between 30 and 0 volts, and in between the extremes, the voltage resulting from the voltage division between Rp and Rb.
Likes 1 person
I think it is commonly referred to as a Manually Controlled Variable Potential Reduction Demonstrator. (just kidding)
Controlled Level Indexed Total Offset Resistance Indicator System
baaaaaad boyyyyyy. That'll cost you 2 points at least!
How about
Hybrid Electromotively Adjustable Thermal Efficiency Reducer.
I don't really see how you could get 30 V across the load with this set-up. If it is indeed a potentiometer, than Rp can either be in series with the load or in parallel with the load, or somewhere in-between. Either way, Rp would have to be zero and in series for 30 V to appear across the load. My apologies if I am wrong.
If a potentiometer is adjusted to its top adjustment the series resistance will be zero. Rp will appear in parallel with Rb
Right. My apologies! My head was in a book all day, so I for some reason was not comprehending that.
Not a Red Dwarf fan then?
... that goes on the right, if the adjustment is not electromotive then it has to go on the left.
Presumably OP has the answer.
From Red Dwarf? ---- that means 4 points. Deriving jokes from silly-shows is not considered acceptable forum behavior.
(Haven't seen much Red Dwarf. Maybe 5 or 6 episodes. It was a bit much for me. I'm more of a Lexx guy if you can believe that).
FAQ: Name of this electrical circuit?
1. What is the purpose of this electrical circuit?
The purpose of this electrical circuit is to control the flow of electricity in a specific way to perform a desired function or operation.
2. What components are needed for this electrical circuit?
The components needed for this electrical circuit may vary depending on its specific function, but generally it will require a power source, conductors, resistors, capacitors, and switches.
3. How does this electrical circuit work?
This electrical circuit works by using the properties of its components to control the flow of electricity. The power source provides the energy, which is then directed through the conductors to the necessary components, such as resistors to control the current, capacitors to store charge, and switches to open or close the circuit.
4. What are the safety precautions for working with this electrical circuit?
Some safety precautions to consider when working with this electrical circuit include wearing proper protective gear, ensuring the circuit is disconnected from power before handling, and following proper wiring and handling procedures to avoid electrical shocks.
5. How can I troubleshoot issues with this electrical circuit?
If you are experiencing issues with this electrical circuit, some troubleshooting steps may include checking for loose connections, testing the components for functionality, and consulting a circuit diagram or expert for assistance.
