How Do I Correctly Name Organic Compounds and Handle Isomers?
In summary, the conversation is about naming compounds and drawing chemical structures. The first question is about the correct naming for a molecule with a branch off of the second carbon, which turns out to be 3-methylpentane. The next two questions are about drawing molecules with brackets, with the advice to use the bonding rules and remember the number of bonding electrons for Carbon. The conversation ends with a request for help and appreciation for any assistance.
danago
Hey. I've just started organic chemistry in class, and I am currently up to naming compounds, and isomerism.
Ive been going through some excersizes, and came across a few questions I am having trouble with.
The first one:
http://img136.imageshack.us/img136/870/3methylpentanech5.gif
The answer book says its called 3-methylpentane. I can't understand why though. The longest carbon chain consists of 5 atoms, therefore making it a pentane, but from what i can understand, there is a branch off the second carbon, so i would have thought it would be called 2-ethylpentane, but apparently not. Where am i going wrong?
The next two I am very confused with. How do i draw them? I am a little lost as to how to handle the brackets.
[tex]
\begin{array}{l}
(CH_3 )_2 CHCH(CH_3 )_2 \\
CH_3 CH_2 C(CH_3 )_2 CH(CH_2 CH_3 )CH_2 CH_2 CH_3 \\
\end{array}
[/tex]
All help greatly appreciated.
Thanks,
Dan.
Yeah your correct, the longest being 5 C's long is pentane, but the branch is just a single methyl group at the thrid carbon of that branch (attached at the CH ).
to draw it another way:
Code:
       CH3
CH3-CH2-CH-CH2-CH3
For the brackets, you can see that in the first one you have all methyl groups within the brackets and you can deduce that they can only be singly bonded. Use the bonding rules to predict the shape, remembering how many bonding electrons Carbon has. There should be only one result (unless it is an isomer).
Hello Dan,
Naming organic compounds can be challenging at first, but with practice it becomes easier. In the first compound, you are correct that the longest carbon chain is 5 atoms, making it a pentane. However, the branch off the second carbon is a methyl group, which is considered a substituent. When naming compounds, we start by numbering the carbon chain from the end closest to the substituent. In this case, the methyl group is on the third carbon, so we name it 3-methylpentane. If the substituent was on the first carbon, it would be called 1-methylpentane. The number before the substituent name indicates the location of the substituent on the main carbon chain.
For the second compound, the brackets indicate a repeating unit. So in the first compound, there are two methyl groups attached to the second carbon, and in the second compound, there is a methyl group attached to the third carbon and a ethyl group attached to the sixth carbon. These repeating units can be simplified by using parentheses and a number to indicate how many times they repeat.
For the first compound, it would be written as (CH3)2CHCH2CH3 and for the second compound, it would be written as CH3(CH2)2C(CH3)2(CH2)2CH3. The numbers outside the parentheses indicate the location of the repeating unit on the main carbon chain.
I hope this helps clear up any confusion. Keep practicing and you will become more comfortable with naming compounds and handling brackets. Good luck with your studies!
FAQ: How Do I Correctly Name Organic Compounds and Handle Isomers?
1. What is the purpose of naming organic compounds?
The purpose of naming organic compounds is to provide a systematic way of identifying and classifying different types of molecules. This allows scientists to communicate and understand the structure and properties of compounds more effectively.
2. How are organic compounds named?
Organic compounds are named according to a set of rules established by the International Union of Pure and Applied Chemistry (IUPAC). These rules take into account the number and type of atoms, their connectivity, and their functional groups.
3. What is the difference between systematic and common names for organic compounds?
Systematic names follow the rules set by IUPAC and are based on the structure of the compound, while common names are often derived from historical or traditional names and may vary between languages and regions. Systematic names are preferred in scientific communication.
4. What is the purpose of functional groups in organic compound names?
Functional groups are specific arrangements of atoms within a molecule that determine the chemical and physical properties of the compound. They are included in the name to provide important information about the structure of the molecule.
5. Can two different compounds have the same name?
No, according to IUPAC rules, every compound must have a unique name. However, some compounds with similar structures may have similar or even identical names, but they will have different prefixes or suffixes to differentiate them.
